Lower frame engine dimension and sizing GMC SAFARI 1991
Is anybody know dimensions or size of a frame where fits engine (lower frame)
maybe some manual or scrapbook with sizes of a frame?
p.s.front wheel drive
Re: Lower frame engine dimension and sizing GMC SAFARI 1991
None of these vans are front wheel drive.
Try giving more detail and possibly someone could help
1999 Safari Touring edition.
teal green
300 000 kms
teal green
300 000 kms
I think you will just need to measure it up....
The size can vary depending on where you look at it...
I imagine by Front wheel drive, you actually meen All wheel drive?
Control sizes of a frame?
Car drive rear! 4х2 Leading back bridge!
These vans do not have a separate frame from the body. They are a unibody the built in frame rails are 2x4 inches. The engine , transmission and front suspension mounts to a subframe that bolts to the front of the van. I hope this helps it is hard to tell exactly what your asking with the translator your using.
teal green
300 000 kms
teal green
300 000 kms
All thanksKidhauler wrote:These vans do not have a separate frame from the body. They are a unibody the built in frame rails are 2x4 inches. The engine , transmission and front suspension mounts to a subframe that bolts to the front of the van. I hope this helps it is hard to tell exactly what your asking with the translator your using.
That sure is handy. Was there a 2000 All-wheel-drive diagram where you found this one?
Or other years?
1995 Black LT AWD
2000 Ninja ZX-6R
2000 Ninja ZX-6R
timelessbeing wrote:That sure is handy. Was there a 2000 All-wheel-drive diagram where you found this one?
It is necessary for you?timelessbeing wrote:hmm... looks kind of scrambled.
Nice diagram.Took a copy for my photobucket account.
If it where mine,the minimum would be square tube 2 x 3,but even better like 2 x 4.
There is a user name by Astroracer on:
http://www.clubhotrod.com
In the shop talk section,suspension sub section that is building a complete frame and mounting a Astro body to it.It is one of the most elaborate profession home builds I have ever seen for a Astro van.I think he used 2 x 3 square tube for his.Might want to check that out.Mark really does know his stuff.Has CNC design capabilities.
Before I forget.Astro vans have a very wide wheel base.I found that out by trying to dolly tow them with rental U-Haul dollies.The only way they fit is by using the narrow spare tires on the front.
Gary do you have a link to the thread with the full frame? I tried looking but cant seem to locate it....1Gary wrote:Nice diagram.Took a copy for my photobucket account.
1995 Black LT AWD
2000 Ninja ZX-6R
2000 Ninja ZX-6R
