Broken G80
photo_van
Been thanked: 3 times
Broken G80
Post by photo_van »
Well my locker hasn't been working for sometime. Took a look in there today, everything looked ok, but there was a 1/2 long chunk of metal stuck to the magnet :yikes: I guess that might have something to do with it.
Rebuild or replace; with what? Opinions?
Re: Broken G80
Post by mdmead »
Custom 9" or Dana 60 with air locker. (Hey, it is easy for me to spend your money!) :muhaha:
ihatemybike
Re: Broken G80
Post by ihatemybike »
I bought Grumpy's G80 rear end from a scrap yard for $126.
Maybe give http://www.car-part.com a search.
I've recently acquired a low price source for new drivetrain parts.
Here's what I see available. I'll get prices.
Auburn Pro Series
Eaton Posi
Detroit Truetrac
Detroit Locker
photo_van
Re: Broken G80
Post by photo_van »
Are these G80 prone to failing compared to other lockers? Only 90,000 pretty easy miles on this one.
Has thanked: 47 times
Been thanked: 25 times
Re: Broken G80
They don't like being shock loaded.
ihatemybike
Re: Broken G80
Searching the forums, I wasn't able to find many broken G80s. Broken 7.5/7.625 rear ends I was able to find several.
My normal cheap source for new drivetrain part quoted me higher than Summit Racing prices for LSDs and Lockers.
photo_van
Re: Broken G80
Post by photo_van »
Thanks for the link Aaron, that's a good one for me as the nearest salvage yards are three hours away!
Timeless; the shock loading is a problem, unfortunately at slow speed that's what happens, one wheel starts to spin and the other is stationary, that's a lot of static mass. There appears to be some "dainty" parts in the G80 and I'm wondering if any of the others are "beefier"?
Re: Broken G80
Post by 1Gary »
Zam had Lifted put in a posi in his van.Might want to PM Zam about the details.
Re: Broken G80
If you have the money, I feel the best posi is a Detroit True-trac. They require a complete setup as will any carrier you place in there. I installed a Power Trax no-slip locker in zam's van. It was an actual locker and not a posi.
photo_van
Re: Broken G80
Post by photo_van »
Thanks Dean; I'm assuming the G80 is LS and not locking? I'm saving up to treat the old girl for her 100,000 mile anniversary. Thought she might like a low range and some 4:11's to make the second half of her life a bit easier. Might as well fix the locker while we're in there. It will be interesting to see what broke on the G80.
Re: Broken G80
It's kind of a hybrid. It does lock the axle for 50-50 power distribution but it behaves reactively.
Re: Broken G80
If you are swapping 4.11's in, you might as well save a little more for the True-Trac. The G80 is a locker but it operates in a finite speed range. The fly weights disengage it above about 30 mph.
Re: Broken G80
Post by mdmead »
photo_van wrote:Thanks Dean; I'm assuming the G80 is LS and not locking? I'm saving up to treat the old girl for her 100,000 mile anniversary. Thought she might like a low range and some 4:11's to make the second half of her life a bit easier. Might as well fix the locker while we're in there. It will be interesting to see what broke on the G80.
There was a discussion on the G80 several years ago and I thought the G80 was a limited slip. Dean posted up a video... proving me wrong! I'm not sure if this is the same video, but it gives a pretty good explanation. (The G80 is really a pretty impressive piece of work.)
[youtube]http://www.youtube.com/watch?v=tTGZOJQQBeE[/youtube]
Re: Broken G80
photo_van wrote:I'm assuming the G80 is LS and not locking?
Forget terms such "limited slip", "locking", "positraction", "stability control" etc. Find out how stuff actually works! Every unit is different so putting it in a pigeon-hole is deceptive. You'll find that terms like bias, ratio, and distribution have more meaning than the marketing jargon.
Things that you need to know about the G80 are that it is reactive. In other words, one wheel needs to slip roughly 100RPM before you get any benefit. Torsen differentials are active so they are constantly adjusting torque distribution to keep you from slipping in the first place. The G80 has more or less two modes: open and 50/50 split, and as Lifted said, a narrow speed range that it can operate in. The Torsen, can never give you full 50/50 split and it is possible to get into a one wheel spin, but it works at all speeds and allows speed differentiation in turns. The Torsen also has far fewer parts and no clutches.
Cobra
Re: Broken G80
Post by Cobra »
i think knowing the difference in a diff that locks the two axles together and one that allows one to rotate slightly faster then the other is important, so limited slip, locking and open do all have useful meanings. As far as i know all differential do one of those three things so if I understand anything about this G80 is that an accurate description would be a low speed reactive locker?
also i mentioned a long time ago that GM used the G80 code on many vehicles but from what i can tell all it means is there is some sort of traction aid in the rear axle (someone please correct me if i'm wrong) the Torsen (which i would put in the limited slip category) i just put in my 98 is the G80 for a camaro. There is another thread on here with more info on the Torsen and lots of good stuff on the net one of the reasons i picked it was the relatively simple design and no clutches to wear out.
