Need disc brake swap info
Keithrus
Post by Keithrus »
Hey there. I'm new and looking for information about swapping out a drum break rear end for disk brake. I have a 1994 G30.
Any ideas what newer year fits? Thank you.
Has thanked: 47 times
Been thanked: 25 times
Re: rear end
Hi Keith. Welcome to the forum. In the future, please don't post van help questions in the Welcome section. Thank you.
(Moving this to the G-series Van section)
Re: rear end
Keithrus wrote: Thu Sep 15, 2022 5:04 pm information about swapping out a drum break rear end for disk brake.
For most people drum brakes are sufficient for the job
Unless you're doing heavy duty towing, swapping isn't worth it and you won't notice an improvement.
-rear drums last 3x longer than disc
-they need less servicing, no pins or brackets to clean or lubricate
- because they're enclosed they collect less debris kicked up by front wheels
(they actually went back to drums on the 1500 pickups in 2009)
semi metallic pads are better and make sure your drums have a good machined surface (not glazed)
