body bushing problem
Re: body bushing problem
you have assembled the lower part incorrectly, the rubber ring goes in first, the hard donut cushion goes in second, the steel washer, then the through bolt. the top bushing also has a oval slot, it has to be rotated to the correct orientation to drop into the subframe.
Thanks for the help brokenwrench
1997 RWD Astro
1995 GMC Safari 4x4 lifted 5"
I have a 2005 all wheel drive Astro van will 88 - 99 cab mount bushings on a Chevy truck work on my sub frame of my van?
I used prothane part # 7-108 for the bushings in my 95 gmc it will work for all years
1997 RWD Astro
