We have all talked about how tire sizes impact gas mileage.We have also talked about how these mods in tire sizes and wheels impact the stock suspension parts like tie rods,idler arms,etc,which are not built for it and shorten those parts life.
The question here is with a 3" pipe lift and about the same in the rear,what is the limit I could go to so as not to have that adverse effect on the stock parts and gas mileage??.Ford 9"rear end ratio of 3.70's.
Wheels/tire sizes
Wheels/tire sizes
Re: Wheels/tire sizes
What size? Stock, but that's no fun.
Usually people match the tire to the lift.
2" = 235/75R15 (29")
3" = 30x9.5R15
4" = 31x10.5R15
Any lift will cause you to lose mpg do to increased aerodynamic drag.
3" = 30x9.5R15
4" = 31x10.5R15
Aaron
Prev Astros:99,97,00,94,87,86
The basis for this question is the compromise of tire sizes/rims that would not effect stock steering parts as much.Honestly I am looking for everyones input,but more directly from Lifted or Lockdoc.I have read Bill say that if you use this size tire it would result in a shorten life and that I think is a real assessment of the situation.
ihatemybike wrote:What size? Stock, but that's no fun.
3" = 30x9.5R15
4" = 31x10.5R15
I don't want to hijack here.. But i was looking at puttinh 235/75R15 on my safari. It is stock height. Will i have issues with those fitting in the wheel wells???????
1999 Safari SLE. Stock. Proud owner since May 2010. So far I love it..
P1050479 by leadtrombone, on Flickr
The old cars - my progression to here (most recent first)
1996 Honda Passport
1988 BMW 320i touring
1989 BMW 520
2005 Chrysler Sebring Convertible
2002 Dodge 1500 Quad Cab
1989 BMW 320i
1990 Toyota Tercel EZ
1991 Mitshubishi Mirage
1970 Mercedes Benz 250 Saloon
1996 Honda Passport
1989 BMW 520
1989 BMW 320i
I tried putting 235/75R15 BFG ATs on my 94. The rear was fine, but there was serious rubbing on the rear of the front wheel wells when turning. Looking under Grumpy, it appears that the sheet metal can be cut and made to clearance. I don't recall anyone ever doing it though.
I ran 235/70R15 BFG Radial TAs on my 2000, minimal rubbing when turning.
Aaron
Well... a good thing i haven't already bought them...
I guess i will have to stick with 230?? 225's
Hmmm.. Well enough hijacking for now.. I should start another thread for those questions...
Sorry to interrupt 1Gary.
1996 Honda Passport
1989 BMW 520
1989 BMW 320i
1996 Honda Passport
1989 BMW 520
1989 BMW 320i
- For rims...it is only an issue of weight. The lighter the better (unless you're rock crawling or packing serious weight). I'm going to say that the stock aluminum rim would be hard to beat for weight and load rating without spending quite a chunk of change.1Gary wrote:The basis for this question is the compromise of tire sizes/rims that would not effect stock steering parts as much.Honestly I am looking for everyones input,but more directly from Lifted or Lockdoc.I have read Bill say that if you use this size tire it would result in a shorten life and that I think is a real assessment of the situation.
- Tires...the shorter and narrower and as solidly ribbed a tread patten as possible will give the best mileage and the least strain on the steering components. Every step you take away from that...equals less fuel mileage and more strain. I think the scale is pretty linear, a 235 will fair better than a 30 etc...
- Steering components(AWD)...leave the torsion bar in the factory setting for maximum life of the steering components. For 2wd...a spindle is the only way to get lift with no affect to the steering components.(not including body lifts)
