Removing drivers exterior door handle
Posted: Tue Nov 06, 2007 5:26 pm
I'll throw this up into the How to section once we get our server issue straightened out
Let me first say that I heard this was a real PITA job,and since I could get in the passenger side it wasn't a must do,but with the winter coming on I felt it was best to get er done 2yrs is long enough,LOL
Big thanks to southern who put up a how to for this with pics awhile back,it certainly helped me out.I've added a few of my own as well which may turn out to be helpful to someone else.
I recommend you wait for a nice chilly dreary fall day with a light semi frozen rain falling kinda like this
Now the 1st thing to do is to remove your drivers door arm rest,there are 2 torx screws holding it down use a T20 to remove
Once there out give a slight pull on the arm rest,the front clip should pop out
you may need a flathead to pushdown on the top rear clip
After you get the top rear clip out you need to pry up on the armrest and pop the bottom clip out
Next you want to take a flathead and gently pry the trim off that holds the door locks and window switches
Once its pried off the panel it will look like this
O.K now it would be a good idea to remove the 30A fuse that provides juice to the doors and windows you'll see why in a minute
Once the fuse is out,you can use that very same flathead screwdriver youve been using to carefully pry the connector off the back of the switches
Once you have both connectors off its time to remove the door panel.There is only one way to do this PULL start from the bottom and work your way up the sides,you will probably NOT get the panel fastners out they will rip off the inside of your panel this cannot be avoided
Once the panel is off toss it in the back of your van here is what the door will now look like
Remove any panel fasteners that are going to be in your way as you will be cutting off the weather panel to give you access
Cut the weather panel and
peel back
Heres a closeup of your interior door handle and lock it means nothing to this venture but I thought I'd be generous and throw it up,lol
If its still raining throw a garbage bag up
Now comes the fun part look up into the innards of your door here is a pic of what you are looking for the nuts that hold your door handle on
Now the bottom nut is simple to get to just remove the little black plug from the edge of your door and use a #10 on a small extension if your lucky your lower nut will break off too LOL
O.k now you need to get a small wrench and start workin away at the top nut,keep pulling the door handle away from the door this keeps the top nut in a position where you can loosen it
Once the top nut is off go around to the exterior of the door this is what you will now see
Just pop the top rod out from the point where it attaches to the handle
I don't yet have a replacement handle so I did the only thing a true canuck would do,put duct tape on it.
I will throw up a couple more pics of the reinstall when I get my handle.
peel back
