your ideas on best all around rear axle gears
I would like to know what you guys think about what the best all around gear ratio for traveling and general driving around.
- Has thanked: 46 times
Re: your ideas on best all around rear axle gears
Copied that chart Timeless.It does leave alot to be questioned when it come to a torque/power curve.But is a ballpark ref.
I think a good all around gear is 3.73's.That is taking into account you V8 conversion as well.
Gary, the numbers in the boxes are engine RPM with a 1:1 transmission ratio going about 65mph.
You decide where that fits into your performance curve.
Oh.it didn't say that.
Mark, there are so many different factors it's hard to say what is best. A stripped down shorty cargo 2WD driving in the flat lands of the mid-west would do great with a 3.08 or 3.23's but a fully loaded 2005 AWD is a dog with 3.42's. It all depends on the driving style, type of terrain and ambient outside temperatures.
I really liked the 3.08s in my 2wd shrorty, but it had a 5 speed, so not sure how it would be in an automatic...
Same van now has 3.73s, and on the highway I'm always wanting to shift up into 5th , but I'm already there...
Let me look in my crystal ball.........aaaaa there it is.I see a 6 speed Tremic in your future.doyoulikeithere wrote:I really liked the 3.08s in my 2wd shrorty, but it had a 5 speed, so not sure how it would be in an automatic...
I changed from 3:42's to 3:08's when I built the 12 bolt. It works fine. I really didn't feel much difference. My van is primarily a highway vehicle. I did the change to get a bit more MPG.
Nice chart TL. Thanks.
+1!1Gary wrote:Let me look in my crystal ball.........aaaaa there it is.I see a 6 speed Tremic in your future.doyoulikeithere wrote:I really liked the 3.08s in my 2wd shrorty, but it had a 5 speed, so not sure how it would be in an automatic...
-James
1987 LT
249,000 miles
1987 LT
249,000 miles
I have an 87 shorty with a 4 inch lift, 235-75-15's and I'm planning on 3.73 with a Gov-Loc... I know I need to get a set of 28 spline axles... The question is, Is the 3.73 too high a gear??? I'm not sure but the one the van has now is a 3.28 I think...
'97 Astro 2wd, lowered 4" w/Belltech spindles and drop leafs.
'87 Astro 2wd, lifted, pretty close to 4" all around.
Never gonna happen,6spd_monte wrote:+1!1Gary wrote:Let me look in my crystal ball.........aaaaa there it is.I see a 6 speed Tremic in your future.doyoulikeithere wrote:I really liked the 3.08s in my 2wd shrorty, but it had a 5 speed, so not sure how it would be in an automatic...
Its in a 4x4 1987 Shorty - with 3.73 and a G80 and 235-75-15 tires... (To MadSlammer - sound familiar?)
Do they make that transmission in a 4wd style?
The table above is supposed to be for a "1:1 transmission ratio going about 65mph.", The 700r-4 has a fourth gear that's .70:1 s... That's pretty close to the .73:1 5th gear on the T-5. So i guess it would be better to run 3.42's or fit 31"s under the van... ???
I'm quite thankfull for the 3.73 when in the bush starring up a steep gravel hill, or towing a heavy load !madslammer wrote:The table above is supposed to be for a "1:1 transmission ratio going about 65mph.", The 700r-4 has a fourth gear that's .70:1 s... That's pretty close to the .73:1 5th gear on the T-5. So i guess it would be better to run 3.42's or fit 31"s under the van... ???
What do you want to use the van for?
mine isnt really intended for a lot of highway use, I have other vans for that.
I don't really use it off road, but rather I need it to perform well all around... It's mostly highway used, with the occasional dirt road and slightly muddy situations...doyoulikeithere wrote:I'm quite thankfull for the 3.73 when in the bush starring up a steep gravel hill, or towing a heavy load !madslammer wrote:The table above is supposed to be for a "1:1 transmission ratio going about 65mph.", The 700r-4 has a fourth gear that's .70:1 s... That's pretty close to the .73:1 5th gear on the T-5. So i guess it would be better to run 3.42's or fit 31"s under the van... ???
Thanks...
