Stripping and Polishing Aluminum Rims
I picked up a set of aluminum rims. 2 of which needed to cleaned. I bought heavy duty paint stripper from Lowes and carefully applied it to one rim at a time. It took about 3 applications to strip the rim. I was careful not to get any stripper on the gray area which still looked nice. I used 320 sand paper to remove the oxidiation. I sanded in the direction of the smalls lines. Then I used 0000 steelwool to lightly polish the rims in the same direction as the sand paper. I used a drill with a buffer attachment that I got at Lowes. It is a 4 inch buffering wheel for a bench grinder. I also purchased the drill attachment so I use it on my drill. I buffed the wheel with rubbing compound. Considering the condition it came out real nice. I am not applying clear coat because it is easier and cheaper to repolish the rims with Mothers Mag Polish.
- Has thanked: 46 times
Re: Stripping and Polishing Aluminum Rims
Nice work. I would do the same to my mags, except they wouldn't match the rest of my van (not very shiny). I really hate that clear coat stuff.
- Has thanked: 2 times
Wow, so nice. What a difference.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
K&N air filter
Looks great!
I have a set,I was thinking of cleaning up & re-clearcoating. Thanks for changing my mind!
DHC Rock rails
Fiamma awning
DHC Rock rails
Fiamma awning
those look great. I need to strip and polish the rims on my van. the clear coat looks like crap and theres oxidation from wheel weights damaging the finish.
00 safari high top explorer conversion. "shagfari" 235xxx miles on body. 242k on junkyard Jimmy motor.
94 safari hi-top explorer limited. 132k miles.
95 ASTRO choo choo conv. RIP @115K
97 safari slx "surfin' safari" 145k miles RIP
91 safari shorty Tiara conversion. RIP
86 cadillac fleetwood brougham. 67k. It thinks its a hot rod.
83 lesabre limited. 71k miles
66+68 toronados
66 Riviera
66+68 toronados
66 Riviera
