Clean out the grime.
Tap in your new bushings.
Follow previous steps in reverse to reassemble. Make sure you get the pins in far enough so the barbed clips pop out.
Bob's yer unkle! Now the post lines up nicely with the latch.
Door alignment
- Has thanked: 46 times
Re: Door alignment
Don't know Bob but I bet he's proud! Thanks for the pics, mines up for tweaking too! Kelly
"S.S. Dark HoMutt"
1999 Chevy Astro AWD
1991 Chevy Astro AWD(retired)
"S.S. Dark HoMutt"
Re: Door alignment
I an doing the door pins on the driver's side on Rufus this week.I am guessing someone else had been in there before and didn't put back the door spring.So because you used it on your van and pictured the door spring compressor tool in this thread,I picked one up before going to the pick and pull to get a spring.BTW-thank you for that.Man that spring does have some serious pressure!!.So I fought with getting one off a truck at the pick and pull until I figured out you have to pull out the wiring boot off and gain access to tighten the tool threw the hole from the wiring harness in the door.I am hoping that I can pull the pins without totally removing the door and having to remove the door panel/harness.Use a floor jack to support the door with a helper to hang on to it and just move it out far enough to be able to remove the bushings and replace them with new ones and then angle in the spring/tool to put back a spring.But the point of this thread is to say thanks for the tip on the door spring tool .Without it I never would have gotten the spring off.timelessbeing wrote:Clean out the grime.
Re: Door alignment
I just learned that this step is unnecessary ...timelessbeing wrote:Next, I removed the door trim. There are two torx bolts in the handle under some plastic covers, and one philips screw beside the tweeter. The rest is held with clips. Peel off the foam membrane and unplug all electrical connectors.
97CargoCrawler wrote:The wiring harness does unplug right down near the bottom of the side footwell near the parking brake. It is not to bad, just remove the cover plate there and unplug two connectors and the pull the boot out of the body along with the wires. The harness is maybe only a foot long past that boot as it goes into the van.
