Alternator replacement
Re: Alternator replacement
I also decided to paint my battery tray while I had everything apart. It was pretty rusty.
Good photos! I like the flowers you painted on your battery tray
I didn't pull the dog house but it would have made it easier. An open end (10mm?) on the inner nut works well to keep the terminal (and post) from turning.
Looks like you got the improved tensioner.
I went to NAPA and bought a bearing for the tensioner & idler pulley for $7 each, took less than 10 minuets to replace the bearings, I did this when I replaced the alternator a while back, took care of some noise I had.
That's good to know about the bearings. But just going by feel, the spring in the new tensioner was much tighter compared to the old one. Also, the old tensioner was vibrating in the direction of pivot motion.
For me the post didn't turn at all. Friction from corrosion may be causing the the terminal to stick to the outer nut. Maybe some lube would help.photo_van wrote:An open end (10mm?) on the inner nut works well to keep the terminal (and post) from turning.
Is it? I thought it looked identical to the old one, but maybe I missed something.photo_van wrote:Looks like you got the improved tensioner.
Last edited by MountainManJoe on Mon Dec 05, 2011 5:11 am, edited 1 time in total.
Is it? I thought it looked identical to the old one, but maybe I missed something.[/quote]photo_van wrote:Looks like you got the improved tensioner.
An improvement over the one that (like on my van and others) self destructs at the pivot and falls off completely.
I think I'll Plastisol my battery tray when the time comes.
My voltage is unstable while driving. It dips all the way down to 13.9V sometimes. That's not normal, right? Shouldn't it be regulated to 14.4V and stay there all the time? I'm wondering if the alternator is crappy, if this is being caused by my battery which is on its last legs (internal shorts?), or a poor connections somewhere. I'll have to get in there with a multimeter when I get a chance. Maybe hook it up to a different battery.
A battery with cells starting to go bad will harm a alt/regulator.It causes heat.
TB,
It really depends on the things being run at the time.
Front and rear ac blowers on full, will pull mine to just below 14.
And returns to a normal range when I turn them down or off.
I wouldn't worry about it unless it's happening without a load.
