Rubber Bump Stops - Part Number Help Please
Ben_R
Post by Ben_R »
Whilst under the van today I noticed that the rubber bump stops (if that is the correct name) at the rear of the van have dried out, cracked & split.
I have had a look at Rockauto for the parts but can't seem to find them. I know they must be there but I'm unsure what they will be listed under.
I have attached a picture I have found online from an EPC and circled the parts in red that I need to order, the van in question is a '96.
Thanks in advance :)
VanGoGo
Re: Rubber Bump Stops - Part Number Help Please
Post by VanGoGo »
I just happen to have my bumpers off my 99 Astro right now, the number on the part itself is: 15152251
they are also yellow (just noticed that) Hope that number works for you~
"BOYCOTT AUTOZONE!"
Post by 1Gary »
Ben-check your R&P thread.
unrreal
Post by unrreal »
here is a link to the gm parts website: is gonna be number 14.. and the part# 152251 http://www.gmpartsgiant.com/Page_Produc ... =TM0703102
Post by 1Gary »
http://www.timbren.com/ Ben.............
Ben_R
Post by Ben_R »
1Gary wrote:Ben-check your R&P thread.
1Gary wrote:http://www.timbren.com/ Ben.............
Ben_R wrote:
1Gary wrote:Rather than replace those bump stops if your going to carry some wt around Ben,this might be a better solution for you.
I'm not looking to carry much weight but I guess the upgrade will help with the drivability of the van
I did post a reply :)
I have found the ones in the link, are they correct as they look a little different? http://www.timbren.com/timbren-applicat ... MRASTB.pdf
Dayne66
Post by Dayne66 »
WOW! Resurrecting a decade old thread.
Got under my van and the rear bump stops are all but gone. Dealer wants $110......Lordco a bit better at $90 each. Anyone have an alternative?
Do Gm truck ones work? Amazon has them for $40 for a pair. No wreckers around here have any vans to pick from.
Has thanked: 47 times
Been thanked: 25 times
Rockauto $32
