Junkyard hitch ID
Junkyard hitch ID
didn't find much info on draw-tite's website, all the hitches look a little different than this one. I pulled the hitch from gen1 ext cargo, all the bolt holes appear to match up on my 1999 passenger van, trying to figure out what class it is
1999 Astro 7-Passenger Van
Federal Government Fleet Vehicle
Cadet Blue 4.3L V6
Rear A/C & Heat
RWD G80 posi with 3.42 gears
40,000 miles
Re: Junkyard hitch ID
Looks like a "class 2" to me.
going off the tow ratings which are the max for our vans it is a class 3 hitch. It is nearly identical to the class 3 hidden hitch that I put on one of my vans a few years ago.
1999 Safari Touring edition.
teal green
300 000 kms
teal green
300 000 kms
Definitely a class 3 with WDH.
Thanks for all the help, I'll be towing a boat about 5000# wet so now I need to find a decent WDH system
Cadet Blue 4.3L V6
Rear A/C & Heat
40,000 miles
It is not a weight distribution style hitch it is a weight carrying ball mount style hitch. There are no stabilizer bar mounting brackets.
Due to the lack of stabilzing bar mounting brackets you would go by the 3500lb load rating and the 350lb tongue weight.
If it accepted stabilizer bars then, yes you could tow a 6000lb trailer but this hitch is only designed to haul 3500lbs with 350lb of that 3500lbs on the ball.
Peter
Peter
The 350/3500 rating is the max for a class 2 hitch.
Yes and no. True it does not have the mounts for the WDH bars. It does however accept a hitch head that is part of a WDH. Hence the double rating.Kabey's Van wrote:It is not a weight distribution style hitch it is a weight carrying ball mount style hitch. There are no stabilizer bar mounting brackets.
Peter
From the Draw-Tite website...Linky. Check the WC/WD capacities listed.
Great info, thanks a lot, can anyone recommend a decent WDH system?
Cadet Blue 4.3L V6
Rear A/C & Heat
40,000 miles
Look for one with sway control built in. Some examples:
Reese SC
Eqal-i-zer
These are just 2 examples.
Reese SC
Eqal-i-zer
Thanks again!
Cadet Blue 4.3L V6
Rear A/C & Heat
40,000 miles
