Scanguage II X-Gauge codes
Has thanked: 46 times
Been thanked: 24 times
If you don't know what a Scanguage is, check out http://www.scangauge.com/
I will keep this topic updated with my custom gauges. Enjoy!
(all quantities are expressed using SI units)
_ - _ - _ - _ - _ - _ - _ - _ - _ - _ - _ - _ - _ - _ -
Engine Output Power (kW)
(Max is 140kW for Vortec 4.3)
Code: Select all
TXD: 00
RXF: 400040000000
RXD: 0000
MTH: 017500730000
Transmission (Pan) Fluid Temperature (°C)
Code: Select all
TXD: 6C10F1221940
RXF: 046205190640
RXD: 3008
MTH: 000100010000
Barometer (kPa)
(Standard atmospheric pressure @ sea level = 101 kPa)
Code: Select all
TXD: 6C10F122125101
RXF: 046205120651
RXD: 3008
MTH: 000100010000
Engine run time (mins)
Code: Select all
TXD: 6C10F12211A1
RXF: 0462051106A1
RXD: 3010
MTH: 0001003C0000
Ignition Voltage
Code: Select all
TXD: 6C10F122114101
RXF: 046285110641
RXD: 3008
MTH: 000100010000
Tank Distance Remaining
Code: Select all
TXD: 0044
RXF: 800000000000
RXD: 3010
MTH: 000000000000
Re: Scanguage II X-Gauge codes
I have some more PIDs that I haven't figured out yet. If you have some progamming knowledge, maybe you can help me decode them. Just send me a PM.
