I read somewhere (and can't re-find it) that the 4L80E and 4L60E use a different flexplate. I am assuming that the 3500 series van that my VIN R 5.7 engine came from had a 4L80E, but don't know for sure.
I can't seem to find info on what interchanges, whether I can use the flexplate off of my 1999 4.3 on the 5.7, or what I need to buy to hook the 1999 5.7 to the 4L60E in the 1999 Safari.
I'm having the trans rebuilt and updated, maybe I'll ask the trans guy.
Any Ideas????
4L60E and 4L80E flexplates
Re: 4L60E and 4L80E flexplates
I can't remember anything I do, apparently.
I just took a 700r4 out of a van, and so I went and grabbed the flex plate, and sure enough, the TC bolt pattern is about 1/2" smaller. It is a flex plate that was on a 1988 or so 305. It 'looks' like it has the same bolt pattern on the crank circle and counter weight as the one from the 1999 5.7L.
For the $60 a new one will be, I think I'll just buy one. After all, if my used one is bad, they are a pain to change. Question now is, for what application should I buy it for? Rock Auto only shows one for Express vans, so do all Express vans have a 4L80? I have a hard time thinking that the 4L60E wasn't used in the lighter duty ones, but who knows. They don't list one for the 1999 Astro/Safari, so I couldn't cross referance.
You should b e able to check pretty easily I think, but 3500s should be 80s I believe. You have the right idea getting a 5.7 flex plate. My 80E came with a 454 flex plate, sucky thing is it's externally balanced.
- Been thanked: 18 times
Never let it be said that a question goes unanswered around here, all good things come to those who wait!
'93 cargo, work in progress
Hrrm, trying to think if I have a HD flexplate in mine or not. I know that I have 2 distinct bolt patterns on it, and that the 80E takes the wider of the 2. Since I have the dual pattern flex plate it does seem to bolt up.
