AWD Engage/Defeat switch?
As much as I would love to install the 4WD transfer case, that may be more effort than I really need to take on right now.
Is it possible to install a 3-way switch to either defeat the AWD for mileage, engage the AWD for low-speed, low-throttle crawling or just left standard?
Just thinkin' out loud...
john
2000 LS AWD
2.5" lift, 3.73 G80, Bilsteins, 235/75-15 Toyo A/T's, 2500 Brakes, Skid plate
Ultra-Gauge, Long/Tru-Cool tranny cooler, Electric fans, Bed Kit. 265,000 miles.
2000 LS AWD
- Been thanked: 2 times
Re: AWD Engage/Defeat switch?
I don't remember the yr exactly maybe 97 or 98 and on you could add a switch to disengage the AWD. A couple of the members have done it and I know there are a couple threads about how to wire up the switch around here somewhere.
1999 was the first year for the computer controlled transfer case. There have been a couple on vans modified to turn the AWD off with a switch. It does seem plausible to set it up with a 3 way switch that would effectively add a 4HI mode. Just remember to turn it off on pavement.
Yep, I installed an AWD disengage switch. Basically, just wire in a switch in place of the ATC fuse under the hood. I added an in-line fuse also so that it was still properly fused to be safe. Really simple to do and it actually gave me about 2 mpg.
1988 Astro Shorty full cargo - 350 TBI - 5 speed
1993 Passenger 4X4 Astro 305 TBI V8 -2 speed transfer case 5" custom lift - Built by Lockdoc
2015 Ram Promaster City - work car
2004 AWD Express 5.3
2005 Express 15 passenger 6.0
1984 Beauville Full Size Sport Van- built TBI 355-electric fans- 4L60e 95,000 original miles
2001 International School Bus
Thanks guys! I knew about the defeat part, and was planning on doing that this weekend, but was wondering about the locked engage for crawling around loose, steep scree in the mountains. Figured I do both at the same time...
After some more archive searching I found the thread where it appears there is no way to manually engage the system.
LiftedAWDAstro said this: "There has been no solution to electronically locking the 99 and newer NP136 transfer cases."
Mine is a 2000.
Until I find out differently, I'll go w/ that.
Mine is a 2000.
john
2000 LS AWD
2000 LS AWD
The "engage motor" or whatever it is called is opperated by a PWM signal, and would be hard to replicate to act as 4HI. It would just burn out the motor (actually kind of a solonoid) fairly quickly to put 12+ to it with a switch.ihatemybike wrote:1999 was the first year for the computer controlled transfer case. There have been a couple on vans modified to turn the AWD off with a switch. It does seem plausible to set it up with a 3 way switch that would effectively add a 4HI mode. Just remember to turn it off on pavement.
It is possible, I'm sure, but not easy. The 236 T-case uses an engage solonoid that locks somehow, maybe it could be adapted.
BTW, I have a NP231, both driveshafts and a shifter I'll be selling for a 4x4 astro swap from my '91. I'm going to run a NP241 in my new 4x4, so I doubt the shafts will work. Maybe I should check that before a "speak" too soon, lol.
Where on a 95 is the ATC fuse located?
Thanx,
Don
Thanx,
Don
1995 Astro AWD no lift(?) 30x9.50x15's (only rub a little)
260,000 miles. Flow Master muffler duel out.
I think on a 95, you can't turn the awd off. I'm not sure but I know that the switch thing only works on the newer units.
Logan is correct. The 95 t-case is 100% mechanical and can not be "turned off".
this is probably a stupid question, but could you add an s-10 front diff with a locker with that switch?
New member - greetings all and thanks in advance ;-)
I have a 1998 awd astro and wondering when the 99 electrical awd tweakability came into effect.
Can anyone offer any detail on dates, or some method to confirm/deny my 98 didn't squeak into this category?
Wishful thinking I admit, but 2mpg is 2mpg.
cheers
cheers
tandrews
1998 awd astro 4.3l
1998 awd astro 4.3l
The '90-'98 AWD vans use the BW4472, a mechanical (viscious coupling) transfer case. No adjustments, electrical hookups, etc.tandrews wrote:New member - greetings all and thanks in advance ;-)
cheers
The 1999-2005 AWD vans use the NV136 that uses a PWM solonoid to activate a wet clutch that engages the front driveshaft.
There are a few good explanations of how the systems work here on the site, if I come across them, I'll reply with some links.
So what bad could come from just pulling the ATC fuse and driving in 2-wheel, specifically towing.
2000 GMC Safari SLE AWD
Not sure why you would want to do that. My AWD never engages by itself unless I'm off-road or on snow, in which case it's a very good thing.
Well, as Logan said earlier in the thread he gained 2 mpg... If it's as easy as popping the hood and pulling a fuse to gain 2 mpg during dry summer months, why not?
