Armrest repair 96+
lockdoc
Armrest repair 96+
Post by lockdoc »
I decided to try one of the armrest repair sleeves. Pretty simple to install and looks pretty good. Just unbolt the pull handle, lay some silicone down, install the cover. That's it. I recommend clear silicone. I had a lot of white on hand so that is what I used.
Current:
01 AWD - Stock
98 AWD - Stock
Past:
94 RWD - 350 V8 - sons van
92 RWD - stock - sons van
93 RWD Shorty - project
89 RWD Shorty - parts van
Rileysowner
Re: Armrest repair 96+
Post by Rileysowner »
Looks good. Where can I order one of those?
lockdoc
Post by lockdoc »
Current:
01 AWD - Stock
98 AWD - Stock
Past:
Looks good to me. Is the cover soft like the original?
LaGrasta
Has thanked: 2 times
Been thanked: 3 times
Post by LaGrasta »
No it's not soft like the original. I replaced mine years ago and they've held up very well, not a single crack. My only complaint is WOW they cost a lot!. It can't cost that much to make 'em.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
lockdoc
Post by lockdoc »
I agree. Very pricey. But it's the only thing available that I could find. And yes, it's molded plastic.
Current:
01 AWD - Stock
98 AWD - Stock
Past:
Been thanked: 2 times
Post by astrozam »
Looks good Bill :supz:
crash
Post by crash »
wow.. looks great!! ... but ya.. that cost.. OUCH!
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
99 Astro LS Sept 08 ASV VOM
94 Astro LT
93 Astro LT
96 Astro LT AWD * parts van*
Post by mdmead »
That came out looking really nice!
thefrog747
Post by thefrog747 »
I need those things on both sides too ! I Googled Accu Form Plastics 435-635-9273. I have my message in asking for a distributor near me ...I'll keep you posted.
Has thanked: 12 times
Been thanked: 4 times
Post by Herbie »
Call me the thread necromancer, but I had to bump this one up because it looks like lockdoc's fix is the "defacto" standard now. I was looking for OEM armrests or covers as mine have the typical wear problem, and came across these on eBay: https://www.ebay.com/itm/331743059933?c ... 1743059933 and I thought "Man, those photos look familiar!"
Did a little searching and sure enough, those are the photos from lockdoc upthread...
LOL.
Has thanked: 47 times
Been thanked: 25 times
nice, except I would use a quality adhesive rather than bathtub caulking.
Bret Schmerker
Post by Bret Schmerker »
:-s A hard overlay ain't the same as a proper re-cover. As long as I've latches to get for my M11006, I'm researching the armrest dimensions for the cab doors, as I've a driver-side armrest rebuild in the near future, which means new open-cell foam of the proper spring rate to cut as well as new DuPont® Vinylite™ burlap-backed PVC in a suitable color to cut and sew.
Post by Herbie »
I agree, Bret - the problem being that since the factory rest is basically one-piece with the rest of the interior door skin, it's no small job to recover the arm-rest portion.
Realistically, any recover that doesn't do the whole door is kind of an overlay anyhow! Personally, I just want to stop getting poked in the elbow by the cracked plastic bits.
