Wheel And Tire Information
Topic author - ASV Supporter
Tire Size Calculator
http://www.miata.net/garage/tirecalc.html
Vehicle Bolt Pattern Reference
http://www.discountedwheelwarehouse.com ... erence.cfm
ASTRO/SAFARI BOLT PATTERN
1985 - 2002 Astro/Safari
5 X 5" (5 X 127.0mm) bolt Circle
2003 - 2005 Astro Safari
6 X 5.5" ( 6 X 139.7mm) bolt Circle
Wheel Offset Guide
STOCK 6 1/2" WHEEL
Aftermarket 7" alloy wheel with 3 3/4" Backspace
Aftermarket 7" alloy wheel with 4 1/2 Backspace
Aftermarket 8" alloy wheel with 3 3/4 Backspace
Aftermarket 8" alloy wheel with 4 1/2 Backspace
OTHER VEHICLES WITH 85-02 ASTRO BOLT PATTERN
*note - Offset and hub center will need to be verified as it varys by year and model
71-96 Buick SeSabre
77-78 Buick Riviera
71-96 Buick Roadmaster
68-94 Cadillac Brougham/Calias
68-88 Cadillac DeVille
77-79 Cadillac Seville
71-76 Chevy Belair/Biscayne
71-96 Chevy Caprice (HD)
94-96 Chevy Impala SS
88-98 Chevy/GMC 1/2 ton 2WD trucks
94-99 Chevy Suburban 2WD
95-99 Chevy Tahoe/Yukon 2WD
98-02 Chevy Savanna/Express vans
73-78 Ford Galaxie/Futura
99-01 Jeep Grand Cherokee (wrong offset)
73-77 Mercury Cougar XR
OTHER VEHICLES WITH 03-05 ASTRO BOLT PATTERN
03-up Chevy Savana/Express vans
88-up Chevy 1500 4X4 (including Tahoe, suburban)
99-up Chevy Silverado/sierra 2WD
79-98 Toyota 4X4's
87-93 Mazda B-Series
74-92 Jeep Wagoneer
Wheel Offset Guide
STOCK 6 1/2" WHEEL
71-96 Buick SeSabre
77-78 Buick Riviera
79-98 Toyota 4X4's
74-92 Jeep Wagoneer
'03 VW Jetta TDI
'78 Vette 350 4spd
www.vehiclefleetsolutions.ca
'03 VW Jetta TDI
'78 Vette 350 4spd
Re: Wheel And Tire Information
Great post!
Helwig Rear Anti-Sway Bar
BFG AT KO 235/75/15
Cragar Nomad I Wheels
BFG AT KO 235/75/15
View wheels on your van
Tire Factory
Tire Factory
Can anyone tell me if these will fit my '99 with the lift and 235-75-15 BFG AT tires?
I think white wheels would look pretty nice...
http://cgi.ebay.com/ebaymotors/US-Wheel ... 18Q2el1247
BFG AT KO 235/75/15
BFG AT KO 235/75/15
I might be worried about the sliding door not clearing.... if the back spacing is 6" it may be just a little to much but you can usually get those style wheels in many different backspacings.... be awrae that that white paint turns to rust very very fast!
'03 VW Jetta TDI
'78 Vette 350 4spd
'03 VW Jetta TDI
'78 Vette 350 4spd
Gotta read the descriptions a little better boys. The rim has the same measurements as the "Aftermarket 7" alloy wheel with 3 3/4" Backspace" listed above. The backspace is 3.750" in the ad.
Conclusion, yes they will fit just fine.
ihatemybike...thanks...just wanted an independent 3rd party confirmation. Looking at the chart above, it looked Ok, but want to make certain, if I decide to pull the trigger...
BFG AT KO 235/75/15
BFG AT KO 235/75/15
You know what might be cheaper? Get the wagon wheels off an old Astro in the junk yard and paint them yourself. Grumpy will be using some of these painted red.
Yeah...that's what I really want...guess I need to go scrounging around...
BFG AT KO 235/75/15
BFG AT KO 235/75/15
http://store.summitracing.com/partdetai ... SW-70-5750
Looks like a pretty good deal from Summit Racing....
BFG AT KO 235/75/15
BFG AT KO 235/75/15
Been playing...
1985 - 2003 5x5 lug
Summit Racing
15x7 wheels
15x8 wheels
2003-2005 6x5.5 lug
Summit Racing
16x7 wheels
16x8 wheels
1985 - 2003 5x5 lug
Summit Racing
15x7 wheels
15x8 wheels
2003-2005 6x5.5 lug
Summit Racing
16x7 wheels
16x8 wheels
I ordered them today. Will post pics once I them them installed!
http://store.summitracing.com/partdetai ... toview=sku
BFG AT KO 235/75/15
BFG AT KO 235/75/15
I played with that a bit. I guess I am old school... My fav's are the American Torq Thrust D, with the painted centers, followed closely by the Salt Flat Specials (painted center), old "Daisy" style 5 spoke, the and then the Ansen 5 hole slotted mags.ihatemybike wrote:View wheels on your van
Tire Factory
i see U.S. Wheels and American Racing makes Smoothie wheels.....Does offset come into play? Or is backspacing more detailed in selecting? i'm in the market for 15x7 smoothies.
The US Wheels 15 x 7 Smoothie has 4.125 back spacing.
The American Racing 15 x 7 Smoothie has 4.24 back spacing.
Looking at the rim diagrams above both would easily fit with no problem.
