Yes this is old school,but still the numbers are impressive:
Most rodders know the 500-inch Cadillac V-8 was a reliable powerplant in the traditional V-8 mold. Produced from 1970-’76, the big-inch Caddy powered some of the longest and heaviest cars to ever wear the Cadillac crest. These low compression bruisers were never known for their performance, but rather their silky-smooth delivery of seemingly boundless torque.
While the 500 was built from 1970 until 1976, there were few changes from its beginning until its end. The largest and most significant of these changes was the compression ratio. When launched in 1970, the 500 had a stout 10:1 compression ratio, which was good for 400-horsepower and 550 ft.-lbs. of torque right from the factory! That’s pretty impressive, even among the rest of the muscle car engines offered in ’70. But, like the rest of the great Detroit V-8s, 1970 was the pinnacle year. In 1971, compression dropped to 8.5:1 and power dropped with it.
In today’s age of big-inch, low compression hot rod crate engines, it seems the 500 Caddy (and its marginally smaller companion, the 472) were ahead of their time. The Chevy 502 is a great example. Now offered through any GM dealer, the 502/502 can be had for around $10,000 (PN 12496962) and deliver 502 peak horses and 567 ft.-lbs. It’s a very popular choice among street machine enthusiasts, and thousands are seeing duty across the country.
What we set out to do was meet the torque numbers the big Chevy is delivering for about half the cash outlay. We’re not out to beat the horsepower number on this build because this engine will have no need to spin higher than 4,000 rpm. If we wanted to focus on higher rpm performance and peak horsepower numbers, we know the Caddy could respond, but we wanted a reliable performer to pull a heavy mid-’50s Packard down the freeway in overdrive. For this purpose, high horsepower won’t be necessary, but big torque in the lower rpm ranges will be critical. The 500 Cadillac is perfectly suited for such duty.
One of the most appealing things about the 500 Caddy is its low buy-in price. These engines are readily available as rebuildable, complete cores for a couple hundred bucks (or less) nationwide. They’re simply not hard to find or afford, and this cannot be said about many 500-inch engines. Once acquired, there are precious few modifications required to ensure a solid long-term performance engine. With all this going for it, why has the Cadillac not become even more popular?
We feel it has to do with compatibility. The Cadillac bolt pattern is one that was shared with Buick, Oldsmobile, and Pontiac throughout the ’60s and ’70s, and is commonly known as the B/O/P bellhousing pattern. Modern overdrive transmissions typically have Chevy bolt patterns, with the exception of the 200-4R built in the ’80s. Also, engine mounts and exhaust routing will have to be Cadillac-specific, but we’ve learned these potential roadblocks are also being lessened with help from the aftermarket. The engine’s overall external dimensions are similar to other big-blocks of the era, so this should not scare anyone away either.
After researching the Cadillac and finding a bustling aftermarket anxious to assist us, we have to say there is no good reason not to build a Caddy anymore. What few issues there are with the design have been addressed, and the low buy-in makes it a relative steal when the final power figures are in. Watch as we build a 500-incher from the ground up and then fine-tune it on the dyno. The homework paid off, as you’ll soon see!
Our 500 is from ’74, and also carries the dismal 8.5:1 compression ratio. We immediately remedied the problem with some forged Ross pistons. In addition to boosting our compression ratio up to 9.6:1, they are designed with a dish, which reflects the shape of the combustion chamber. This means there is still a good quench area between the piston top and the flat bottom surface of the cylinder head outside the combustion chamber. Quench areas like this serve several purposes, but forcing the air/fuel mixture into the combustion chamber is chief among them. By controlling where the air/fuel mixture burns, more efficiency is gained. This results in more horsepower, torque, and fuel economy along with reduced emissions. We’re simply burning the air/fuel mixture more effectively.
Follow with us as we add some modern technology and research to the classic big daddy Caddy. The results might have you looking at this powerplant differently. For those budget-conscious rodders among us, know this fact: we’ve never seen so much torque built for so few bucks! Enjoy!
Well it's alittle much for me to tackle,but maybe some of our young bucks or oldtime other hot rodders might want to consider one for their Astro van and make it work.Sure beats the costs of a BBC 502 with similar torque results.
A Astrolac-
Hunnn-Caddy big block swap???.
Call me Gary
1985 Astro-"Ole Yellar"
1994 LT Astro
1981 Winnebago-"Baby"
12'dual axle enclosed trailer
The vendor trailer
1994 LT Astro
The vendor trailer
Re: Hunnn-Caddy big block swap???.
Are you asking about swapping INTO an Astro or Safari or did you read that last night and thought it was interesting so you posted it? Are you bored again Gary?
I for one would be very interested to see a build-up of this old classic. And if they were to fuel-inject it a la Edelbrok aftermarket injection system (which is what I believe Darren has been using with no problems at all), that'd make this build-up all the more interesting.
I doubt it'd fit in an Astro though. From what I remember, the 500 Caddy was one wide muther.
"Just keep swimming..."
97' 4wd Safari
ZZ 502 Ramjet
4"L"80E/NP241C
Ford 9"
Kinky is using a feather.
- Thomas Jefferson
97' 4wd Safari
ZZ 502 Ramjet
4"L"80E/NP241C
Ford 9"
- Thomas Jefferson
Thought I read somewhere the caddy was about the same size as a BBC.
Call me Gary
1994 LT Astro
The vendor trailer
1994 LT Astro
The vendor trailer
We tried to stuff a 500inch caddy motor into a full size g20 van many years ago , it was just toooooo wide to fit in the engine bay even if we moved it forward enough to accomodate the caddy mounts . it just wouldn't fit . no way of getting any exhaust manifolds on it . so i doubt the engine bay of an astro would work either .
But if you went the route Peter did , it might just go with a little fabbing .would be interesting to see .
now the 440 BB fit into a dodge 1/2ton van very nicely .
Caddy motors came with fuel injection from the factory. Even though not 100% compatible with today's injectors they can supposedly be modified for them pretty easily. They are known for being a very durable engine even in stock trim the problem with the later ones is I believe that they have very poor quench because they put the pistons in the bore lower to decrease compression.
As someone who as put a 500 in a car it really didn't need to be in I can say for sure there is no chance it is going to fit in an Astro with anything resembling a stock front half the frame/suspension or body
1994 Astro, 6.5L Diesel RWD. Tiara High-top Conversion
1993 Geo Metro XFi Convertible. 1.0L, Best mileage: 118MPG
2007 DR650SE Set up for Adventure Touring
I too like the caddy engines, I messed with them in the late '80s and early 90's.GEJ wrote: When launched in 1970, the 500 had a stout 10:1 compression ratio, which was good for 400-horsepower and 550 ft.-lbs. of torque right from the factory! That’s pretty impressive, even among the rest of the muscle car engines offered in ’70.
That 400 hp number is brake horse power, and is not even close to what it actually made. I'd guess 200-250 hp at best, having owned several over the years, although both 1970 caddys (one coupe and one sedan deville) both had 472 motors. My 76 coupe deville had a 500, and was a sled. All had great, smoooooth torque, but were not snappy at all.
My "w" motored astro would out run any of the 3 easily.
The 500 is wide, but it is short, and actually pretty light. Prolly the lightest big inch motor out there. Performance parts are out there, but they're expensive, and there's not a lot of selection. You need a rear sump pan for almost all swaps, one from an eldorado will work if you can find one. Best cheap, easy stock mod: install a Cloyse timing gear to turn the cam 6 degrees forward (strait up). Whole different animal.
