no heat
HVAC, heating, cooling, air handling. Anything air temp related.
midnighthunder89
no heat
Post by midnighthunder89 »
Hello,
So I was driving back to school. got half way then the heat stopped working. anyone have ideas of what could of happened?
99 sle awd safari
Another addition to cash for clunkers.
Re: no heat
No heat as in blower stopped or there is cold air only?
peter
Re: no heat
Post by peter »
If it's the fan that stopped, blown fuse, resistance or motor. If the air comes out cold, low coolant level (very) or blocked heater core. Or, vacuum hose cracked, though I think that's more an issue of where the air comes (or doesn't come) out.
"Just keep swimming..."
97' 4wd Safari
ZZ 502 Ramjet
4"L"80E/NP241C
Ford 9"
Kinky is using a feather.
- Thomas Jefferson
midnighthunder89
Re: no heat
thanks it was the blower stopped working i went to drive it today and it was fine does this mean the motor or something is going bad?
99 sle awd safari
Re: no heat
Post by Smiliesafari »
Yes \:D/
midnighthunder89
Re: no heat
i was afraid that might be the answer. well.... i guess i will have to start wearing a coat hat and gloves when i want to drive somewhere.
99 sle awd safari
GnarliSafari
Re: no heat
Post by GnarliSafari »
join the club, i had no ac two years ago, paid some ridiculous amount to have it fixed, worked awesome all summer, then the first time i went to use the heat the blower stopped, i get hot or cold air no problem but it doesnt come out of anywhere but the dash defrost vent. if you are driving for a while its fine but initial warm up and cool down takes a while.
Kabey's Van
Re: no heat
Post by Kabey's Van »
I have had this happen before and this may be your problem as well.
There is a single wire that plugs into the blower motor that comes from the resistor block.
This wire needs to carry up to 25 amps and can cause problems. Disconnect this wire and see if you have power there. It may just require some cleaning up and reconnecting.
If you do have power here and you are unable to get the motor working, you can be satisfied that it is your blower motor that is pooched.
Peter
midnighthunder89
Re: no heat
Ok thanks, I will look for it when it gets warmer it is 1F with wind chill -17F so i only go outside when i have to, or want to... like to play broomball, hockey on ice with brooms.
99 sle awd safari
Kabey's Van
Re: no heat
-17 fehrenheit......whimp :goodman: :muhaha:
midnighthunder89
Re: no heat
it got colder now..... I have been busy with school work and fixing my snowboard
99 sle awd safari
