What did you do to/with your van today?
Re: What did you do to/with your van today?
Thank you for the insight. Yes, I see what you mean . Maybe I can put a round rubber or plastic disc seal and drill a small hole to proper port this one. It was on clearance at HD for $5.
Yes, I would try starting with a pair of very small holes; one under the inlet port, and one under the outlet port.
You can always make them larger, if desired.
WE7X aka Rod Johnson
Issaquah, WA
Issaquah, WA
Started tinkering with my latest acquisition. 03 SLT AWD. 123,000 miles full leather no rust or rot. Vacuumed and windows. New wiper blades fore and aft. Rear arm was frozen so PB Blaster and lots of wiggling fixed that. PB Blasted all the door hinges, side door rollers and door latches. Much better. Interior lites dont respond to door opening so tried to swap the assembly from the 99. Different plug. I’ll see about opening it up and pull just the dimmer relay
When I drove my latest acquisition, the 03 SLT AWD home she had a bit of a skip. Today I pulled the doghouse and figured I’d start with a cap and rotor. A quick run to my local parts purveyor and the job was on. For some reason the screw on the far side of the distributor wouldn’t bite so after a closer look-there were no threads. Just a big chunk missing. Good thing there was a brand new White distributor in a box in the shed so now I’m changing dizzies! No surprises the rest of the way and the skip is gone purring like new. New universal joints in the 99 tomorrow.
- Has thanked: 12 times
- Been thanked: 4 times
Putting my new vinyl cutter to good use...
- Has thanked: 46 times
@Herbie
The image doesn't show up for me. Private content?
Fixed, sorry. Google photos still resists direct linking...
Hi All,
It is great that the forum is back.
Hello Herbie. Do you still have your Astro?
Yes indeed!
Still working on little projects here and there (just fabbed new awning brackets to raise my ARB awning up a bit more - the bag was occasionally fouling on the slider door). I owe my build thread a general update, just to sync up.
We have toyed with selling it, only to be able to get a slightly bigger rig since our kiddo is growing, but so far have found nothing (a) we can afford, (b) that does as much, and (c) fits in our driveway.
Hi Herbie,
I am working on a turnbuckle and 1 1/2" pull-ups to add a simple way to adjust the parking brake cable tension. I will post photos,
Hi All,
The parking brake cable OEM adjuster on my 2003 Astro has always been a chore to use. I got a 4” turnbuckle with 5/16" bolts and a 1 1/2" fixed pulley.
Plan is to rig a way to pull cable sideways to adjust parking brake so it hold van on a hill. Once set, tighten lock jut on the turnbuckle bolt with the right hand threads.
Hooked up the auxiliary parking brake adjuster to my 2003 Astro. It Works well.
I used a square U bolt around my 2x2” steel sub frame extender to anchor the non pulley end of the turnbuckle.
Thought I’d share my progress with the new van with y’all. Feeling pretty good about what I’ve gotten done. So far I’ve:
Replaced fuel pump
Cleaned EGR and replaced gasket
Fixed exhaust leak
New plugs wires and distributor
New tires
Front end rebuild which included
Shock absorbers
Upper and lower ball joints
Upper control arm bushings
Sway bar links and bushings
Inner and outer tie rods
Next on the agenda:
Fix leak coming from oil cooler adapter
Replace viscous coupling
She’s running rich too so I’m going to troubleshoot that once I get the light duty truck fuel and emissions manual that’s in the mail.
There’s also a few cosmetic/non operational stuff I need as well. Might see a WTB add from me here soon
Replaced fuel pump
Fixed exhaust leak
New tires
Shock absorbers
Next on the agenda:
1993 Awd Astro LT 262 ci V6 4.3L CPI
Sounds like a lot of good work, Gunther!
