Page 1 of 2
Transmission cooler or not..
Posted: Tue Jul 22, 2008 3:28 pm
by Detectorist
next week I'll be towing with my stock Astro Van 2000 a 6'X12' Uhaul trailer total weight about 3200lbs. Moving from Largo, Florida to Raleigh NC.
Should I get a transmission cooler installed as a precaution?
Re: Transmission cooler or not..
Posted: Tue Jul 22, 2008 3:32 pm
by astrozam
YES !
Posted: Tue Jul 22, 2008 3:40 pm
by potskie
Most Definitely!!!
The 100 smackers and the hour or so to install it as a precaution is a whole lot cheaper than a new tranny.
Posted: Tue Jul 22, 2008 4:50 pm
by SafariRob
I also vote yes even if you never pull a trailer with your van. It's downright spooky how hot the ATF can get in an automatic transmission. If you want to get freaked out, install a transmission temperature gauge before you install the cooler. I think you'll be surprised at the temperature the transmission gets to. I know I sure was.
Posted: Tue Jul 22, 2008 5:03 pm
by skippy
LOL looks like its a defenate YES . if you do the install youir self , do not use the plastic things you push through the radiator !!!!!!! use the metal straps & mount it to the radiator support . that way you don't wind up with leaks in the rad . or the a/c condensor up front .
Posted: Tue Jul 22, 2008 5:39 pm
by LiftedAWDAstro
Another vote for a YES! It is a must have for daily driving and an absolute necessity for towing.
Here is the stickied thread on installing one yourself. The bottom of page 1 shows a temperature comparison I did on my 2003 AWD in much cooler weather than your Florida to North Carolina trip will be.
Posted: Tue Jul 22, 2008 6:28 pm
by Jim in Indy
Definite yes.
Posted: Tue Jul 22, 2008 6:31 pm
by Rebel
Another yes here.
Hey Rob,,you ever been able to check the difference in temps running aux. cooler only compared to rad. cooler and aux. combo ??
Posted: Tue Jul 22, 2008 6:56 pm
by kings-x59
And...one final yes.
Posted: Wed Jul 23, 2008 4:39 am
by Water Boy
There is no such thing as too big of a stacked plate cooler.
Some of them have a built-in fluid bypass.
Sample....
http://www.transmissioncoolers.us/
Thanks guys, you all are great!
Posted: Wed Jul 23, 2008 9:28 am
by Detectorist
I'm getting a cooler today.
Re: Thanks guys, you all are great!
Posted: Wed Jul 23, 2008 12:14 pm
by Water Boy
Detectorist wrote:I'm getting a cooler today.
When you do the install ... you are gonna install it right? ... take pics and post 'em here.
Posted: Wed Jul 23, 2008 7:29 pm
by Detectorist
No, I don't want to mess with it. I'm having uhaul install their heavy duty one along with the wiring for the trailer. I also ordered a 5000lb hitch from etrailers.
Posted: Wed Jul 23, 2008 8:04 pm
by Spike99
Do ensure they installthe LDP (Low Pressure Drop) design Aux cooler. The bigger the better. Especially for a 9x12 enclosed trailer that has mass amount of wind drag as well (wind drap compared to a "tucked behind" utility trailer).
If the 9x12 trailer contains onboard brakes (it should - when being pulled behind your van), also get your U-Haul folks to install a standard 7 pin connector with a brake controller in your van. Many trailers use full electric brakes. I hear the "Tekonsha Prodigy" brake controllers are the best on the market. For more details, surf:
http://www.tekonsha.com/prodig.html
Posted: Fri Jul 25, 2008 9:13 am
by LaGrasta
adding a cooler... at least 25° cooler. You just doubled your tranny's life.
