hidden hitch for '02 standard length Astro.
Topic author - ASV Supporter
I'm looking for a class III or IV Hidden Hitch for my '02 AWD, standard length van. I can't seem to find the correct part number for my van, only the extended wheelbase van.
The only one that I've found is this...
http://www.hiddenhitch.com/fitguides/hi ... rtno=87516
Can anybody help or suggest a suitable replacement for the Hidden Hitch?
1989 Cargo 5spd. Fiberglass Roof.
2002 AWD LS, white
2002 AWD LS, white
Re: hidden hitch for '02 standard length Astro.
thats the one ,they stopped the shortys around 94 all are extended after 95 i think.
2000 chev blazer 4x4
If its got tits or wheels, its gonna give you problems!
im sure we all know the #1 junk yard rule if it fits in your pocket its free.
really? that's the first i've heard of that.
i thought the LT were the extended versions?
2002 AWD LS, white
2002 AWD LS, white
nope lt is just trim group.
All 1995 to 2005 Astro and Safaris are extended length. The wheelbases are all the same at 111.3". The extra 10" was added to the rear.
wow.
you learn something new everyday...
Thanks!
Thanks!
2002 AWD LS, white
2002 AWD LS, white
- Has thanked: 2 times
Check out the set-up I have on my '98.
http://www.hitches-forless.com/dual_por ... t_main.htm
It provides the class V strength hitch along with the DPS system for serious attachments. I got it to carry my motorcycle.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
K&N air filter
whoa. that's pretty cool.LaGrasta wrote:Check out the set-up I have on my '98.
I may just have to pick one of those up.
2002 AWD LS, white
2002 AWD LS, white
Combined with my rear AirLift set-up, I can carry a bunch of weight off the hitch and completely avoid any sagging. I think the most I've had back there was about 600 pounds of Harley!
I've towed a two axle car trailer loaded with a car and had no problems either. To be able to adjust the rear height with the bags is really beneficial.
K&N air filter
K&N air filter
