I am very close to completing the gutting of my 1995 GMC G2500 Vandura. I'm starting to put a few things together now while I finish the last little things that need to be torn out. I am having some challenges finding a few parts and hoping someone could help. I have searched my typical sites with not luck. Rock Auto, 1A Auto, Parts Geek, Car Parts, Ebay, etc. I am looking a few things.
1. The light bulb that aluminates the selected gear on the console. The bulb looks good, but I figured I would try a new one. If that doesn't work then I have to figure out what I need to do to get it work. I hate chasing wires.
2. An instrument cluster. I have had my radiator essentially rebuilt and it's amazing. I've also installed a new TSU and Thermostat, but the temp on the cluster is reading low - around 120. These vans typically run around 190. I had it tested and it's definitely the cluster. Thoughts on an aftermarket cluster?
3. I have a high top and I'm missing the red cover for the center high mount brake light (3rd brake light). Can't seem to find it anywhere. I'm thinking I could get a "universal" one and just splice the wires together. Hopefully I find the red cover.
4. I have power windows and doors. The front driver and passenger power doors work perfectly, but the side cargo door and rear cargo door do not have the actuator in them anymore. Looks like I need to run the wires from those doors and/or install a new actuator and hook it to the lock. Thoughts on an aftermarket one? I would love to have a key fob.
Thanks!
Where do I find parts for 1995 G2500
- Has thanked: 3 times
Re: Parts
I think the auto recyclers are your only hope. Otherwise you will have to start getting creative with your fabrication skills.
Center High Top brake light - 3rd brake light
My van is a high top and is missing the red cover for the rear center high top brake light. The problem is this, the high top is (as almost all are) not done at the original factory so it doesn't have a GM part number. I've looked at the housing for name with no luck. I've scoured the interwebs with no luck. I'm thinking of buying a universal one and just splicing the wires together. Thoughts on that and/or locating a replacement cover? Thanks
Re: Center High Top brake light - 3rd brake light
You already posted this. Please don't duplicate your question. Merging topics.
Re: Where do I find parts for 1995 G2500
@BHBVan
- Rockauto.com
- Junkyard
- Buy universal intake duct
- Rockauto.com
- Junkyard
It's a 1990. No luck online. Thought someone here might know of one. I plan to check junk yards next time we venture to an urban locale.
