Where do I find a wiring harness
- Has thanked: 3 times
So I made a massive error the other day. While ripping out all the wiring for the old speaker system I got a little carried away cutting wires. I cut the wire harness that goes into the ECM and threw away the ECM. Buying a remanufactured ECM wasn’t that hard to find. However, finding the harness is impossible. I’ve even tried junk yards with no luck. I only cut the top section so 99% is still in tack. Any suggestions?
Re: ECM - Wire Harness
Always provide vehicle details with your questions.
(might as well put them in your signature since you post here often. It's in user control panel > profile)
It would be great if you could post in the appropriate section too please. Thank you.
You said to post in the appropriate section, so I’m asking which section that would be.
1995 GMC G2500
5.7V8
1995 GMC G2500
5.7V8
I heard you.
I don't understand why you're having trouble finding the section. Are they they not clear?
Moving your question to G Vans.
Yes, because I move it there for you. Which is why I posted ...
Not a bit, thanks for asking. But I think you are extremely confused.
