I recently had a used transmission installed by a incompetent mechanic that decided to try to use spacers under my transfer case and grind down my front drive shaft all basically because he did not transfer the transfer plate off my old transmission so transfer case is mounted with oil drain in wrong position, and I guess that caused things to rub so he used lug nuts under transfer case to create space plus grinned front drive shaft with grinding wheel.
This some how caused front engine lower pulley to come in contact with steering crossbars link
when I showed him that the front pulley was grinding away he lowered my front torsion bars to compensate. I bought van with torsion bars cranked up and rear lifted too and never had a problem.
I am posting a few pictures, trying to see if there is normally space between front axle and front oil pan, on mine it looks like engine weight is resting on front axle.
http://yorkpennsylvania.net/astro/images
What is correct front axle clearance
- Has thanked: 46 times
Re: Transmission swap
Yup there should definitely be a few inches there. This guy should not be allowed to go anywhere near cars. He's going to kill people, if he hasn't already.
I'm moving your question out of the "Engine" section and into driveline.
Re: What is correct front axle clearance
had someone send me a picture and it looked like pan rests on front axle on his too?
- Been thanked: 17 times
Bad motor mounts in my '05 cause that issue. Fact that is a 6 liter might have a little cause in that problem too, lol. I'll change the rubbers for poly mounts and put a 1/2" plate under them.
No, there should be clearance there. Find a new wrench!
had a third person send me picture looks same too, pan right on top of front axle. If I could post them on here I would but I did not figure it out yet
It is not uncommon, the newest astro is 17 years old. find one with new motor mounts and you will have clearance.
My '05 when it was built in 2015, granted it's a 6.0 ls swap, lq4 steel block not an aluminum block (add 100 lbs).
The motor was lifted 2" to get the small bit of clearance you see in the second pic. Now 6-7 years later the mounts are worn and the clearance is gone. I need to switch to poly mounts.
regardless of how many pics you see with no clearance it is wrong, not stock, broken, needs repair. Period.
well my problem got worse today, my reverse went out completely, still have forward gears, not sure about over drive.
I am in process of trying to buy a used transmission with only 10,000 miles on it.
The mechanic referenced making sure its the right transmission for my Astro its a 02 4l60e From Tahoe 4WD
any way of knowing if everything is a match?
Yes, unfortunately I'm unfamiliar with the AWD systems. I did not build my '05.
The 4wd TC and transmission from the tahoe may be able to swap in. I built my '93 and know that between the v8 / v6 transmision 4l60e 2WD were interchangeable.
I've read in the forums about TC swaps in order to get 4wd capability so that may be a possibility. Search for transfer case swap. Hopefully someone will see this with more knowledge on the subject than me, good luck!
