rough idle
LaGrasta
Has thanked: 2 times
Been thanked: 3 times
rough idle
Post by LaGrasta »
I just replaced dizzy, full spider/pump. 241k on motor, very well maintained. Everything has been checked out, tuned-up and cleaned. So I'm struggling to find what else it could be. Idles poor, more so in park, but never stalls.
My next step was to inspect hoses for a vacuum leak. Also, the coil has never been replaced. It runs and drive great so probably not the coil. Suggestions please.
1998 Astro, 246,000 miles
K&N air filter
TruCool trans cooler
Has thanked: 47 times
Been thanked: 25 times
Re: rough idle
don't forget the notorious intake gasket.
wouldn't hurt to measure fuel pressure.
LaGrasta
Re: rough idle
Post by LaGrasta »
thanks Joe. It has a new intake gasket, and new OEM fuel pump too so I expect pressure is also good.
K&N air filter
Re: rough idle
bad catalytic converter?
LaGrasta
Re: rough idle
Post by LaGrasta »
sheesh, I'm still struggling with this idle condition. I spent nearly $2k on this! New OEM spider, pump, and dizzy. I just installed an aftermarket Air Idle Control valve, no change. What next, any new suggestions? I do have a P300 code as well.
K&N air filter
Been thanked: 9 times
Re: rough idle
Post by Astrophysics »
242,000 miles. That is great.
1. Check vacuum
2. Check electrical grounds at studs
3. Check fuel pressure
4. Check O2 sensor readings on OBD 2 scanner running real time data
5. Clean throttle body gate with special spray
6. Check compression at spark plug holes with WOT, wide open throttle
to look for ring or valve leak
Good luck
Re: rough idle
Hi
Also, try OEM air filter instead of K&N
Re: rough idle
Also,
11. Spark plugs and cables
12. Cap and rotor for cracks and carbon arc tracks
LaGrasta
Re: rough idle
Post by LaGrasta »
hmmm, of the suggestions, these are the only things I haven't explored:
1. Check vacuum
K&N air filter
WoodButcher
Been thanked: 18 times
Re: rough idle
Post by WoodButcher »
LaGrasta wrote: Tue Apr 05, 2022 8:08 am hmmm, of the suggestions, these are the only things I haven't explored:
1. Check vacuum
How in hell do you do #6?
Every time I have done a compression test I'll pull the fuel pump relay so the engine will not fire, just turn over to build pressure in the cylinder that I wish to read.
'93 cargo, work in progress
Re: rough idle
yeah if the engine is running (especially @ WOT), wouldn't that just blow the ass out of your pressure gauge?
