Yeah, I really like this mount too. I've filed it away in my mind as a future van project. (Just a couple of other minor projects ahead of it though...)LiftedAWDAstro wrote: I might just use this thread as a starting point for mounting the same receiver hitch on the front of my truck to haul bikes while camping!
TOW POINTS, What I Did For The Front. 99 AWD Lifted
Re: TOW POINTS, What I Did For The Front. 99 AWD Lifted
- Has thanked: 12 times
- Been thanked: 4 times
The bolts are long enough, I think. Once torqued down, there's a smidge of the bolt protruding beyond the end of the nut. Can't remember if these are stock bumper bolts or if I got longer ones with the Overland Vans bumper-bracket kit. I could swap the brackets around to put the bumper brackets on "top" (inboard), but I can't figure out how to make welding the side plates to the frame work.LiftedAWDAstro wrote:The only thing I would change is welding the side plates to the frame and placing the bumper relocation brackets on the outside. You also need longer bolts unless they are only started in the pics. By welding the backside of the vertical section to the frame I would not be worried about banging it on rocks or using it for winching.
I should have taken a picture of everything disassembled, but those side "plates" each have about a 12" section of tubing welded to them - that tubing then telescopes inside the main center tube. You can see in this picture that the inner tube extends almost to the innermost bolt-hole:
If I weld the side plates to the frame, those inner tubes would go with them, and there'd be no way to get the center section in-place. You have to pre-assemble it (loosely), bolt the side plates on, then tighten the 4 big carriage bolts that secure the main-tube in the left/right orientation. If those bolts were loose, the main-tube could theoretically slide left/right about an inch, but even with a 90* side-pull you'd still be pulling on those four bolts in shear.
Unless you're talking about welding it in after it's been otherwise assembled? Something to consider, but I'd have to think it through to make sure I'd never need to remove it to service the radiator, etc. and I'd want to get those cooling lines sorted out first...
I was talking about after it was assembled. From all the work I have done on my vans over the years, there has never been a time I needed that space except when I SAS'd the SPB. I used that space for the front hanger mounts.
Here is where I was talking about welding:
- I am merely driving my van
i just ordered the same kit as herbie hoping to make it work , before reading this post. I was thinking mounting outside the frame tho ,it makes more sense inside
Herbie wrote:[I should have taken a picture of everything disassembled, but those side "plates" each have about a 12" section of tubing welded to them - that tubing then telescopes inside the main center tube. You can see in this picture that the inner tube extends almost to the innermost bolt-hole:
Mike, is there any reason that you can't unbolt the inner tubes, then flip (and rotate actually) the main center tube upside down to get the reciever a little higher for increased approach angle?
I looked into that, and it might be possible, but those coolant lines that are now "resting" on the cross tube would be fully in the way at that point. If you could find a way to reroute or bend them (significantly) out of the way, then it's possible.T.Low wrote:Herbie wrote:[I should have taken a picture of everything disassembled, but those side "plates" each have about a 12" section of tubing welded to them - that tubing then telescopes inside the main center tube. You can see in this picture that the inner tube extends almost to the innermost bolt-hole:
I was a lot more worried about it until I saw that the bottom of the receiver tube it pretty much flush with the bottom of the front bumper skin, and it only protrudes a couple more inches forward:
I think if you're THAT close, you'll be close to dragging the front bumper anyways.
Doh! I guess it wasn't designed for off road use in mind, who woulda thought?
I know you won't take this the wrong way, Mike, it's not that big of a deal, I'm just thinking outloud.
As fate would have it, the Astro design makes for a great approach angle and I'm just always thinking to try to capitilize on it's strengths. In this case, it may be more work than it's worth, though.
If I'm off road, of course the recovery shackle will be inserted ahead of time, just in case, and if this is rock (like at Moab or something, it might be a slight hang up. Well you get the picture. But...it is what it is and it'll fine 99.9 % of the time.
Edit: FWIW, the van actually cleaned this on all three points: approach, departure, and break over. The guy following me was off road enthusiast, but sold his monster jeep to build another one, and was in his new stock jk 4 dr with base package tires and he scraped a lot on the departure and said it shocked him because he saw how easily my van cleared.
Yeah, no worries. I'm up for all discussions - and I realize this solution is far from ideal. This was literally the "crap, I'm going to be in some DEEP sand just four days from now and might need to get yanked out" fix. That's one reason I haven't welded anything yet. I do anticipate reworking the whole shebang at some point. Probably just end up with a custom front bumper! ;-)T.Low wrote:Doh! I guess it wasn't designed for off road use in mind, who woulda thought?
Hi Everyone,
I installed the 2 inch lift kit. When the front bumper was off I cut opening in the bumper and mount recovery hooks that are accessed through the bumper. The S10 Chevy Blazer tow hooks work well.
I will try to post photos.
more photos of S10 Chevy Blazer tow hooks mounted thru bumper at time of lift kit install
finished the cut in plastic bumper shield with standard rubber oval gasket for Peterson tail light .
inside view showing that 1 bolt is mounted to frame and requires 1 new hole to be drilled.
use 3/8 bolts or 10 mm.
Very slick!
I agree! Looks pretty damn good! When I get the gear swap done, I may just have to do the same thing plus I need to flush mount backup lights.mdmead wrote:Very slick!
- Has thanked: 46 times
I just wrap a strap around the front crossmember
