Rear heat pipes
chesehd
Rear heat pipes
Post by chesehd » Thu Oct 13, 2016 4:48 am
The rear heat pipes from the engine to the core for my '03 have rotted out and I've recently come to learn that the part had been discontinued by GM. Third party manufacturing would seem to be equally unhelpful.
Anybody have any suggestions on where to source these or have they joined the ranks of the dodo and unicorn?
Thanks!
Ken
2003 AWD
ihatemybike
Re: Rear heat pipes
Post by ihatemybike » Thu Oct 13, 2016 3:53 pm
Boneyards will be the best chance. You might find them on a van that lead an easy life. I pulled fuel lines this way.
The other way would be to trim the lines back to good material, flare them, then clamp appropriate heat and pressure rated hose in place of the corroded line. I did this with the transmission cooler lines.
dvil
Re: Rear heat pipes
Post by dvil » Fri Oct 14, 2016 12:27 pm
.. or just use rubber hose all the way.
1989 parts car
1989 V8 TPI project
1993 AWD parts car
1995 AWD W-engine G80 diff daily driver. For sale
2004 LT AWD LPG
Re: Rear heat pipes
Post by doyoulikeithere » Fri Oct 21, 2016 2:26 am
Ya, my thoughts too. use rubber heater hose, secure it well, and protect it from rub spots.
