The manual calls for a J-29193 tool to set the idler arm taper before putting on the castle nut. I haven't taken the old arms off yet to know exactly what I will be working with, but this tool looks like a long threaded-rod coupler nut that you attach where the castle nut will eventually go. You torque it to a recommended amount, then remove it and put on the castle nut to it's torque setting.
Why the two stages? I don't quite see the reason behind this procedure if this is what it's all about. What special properties does this tool have over a shorter nut? Many people don't even use this tool apparently. They just put on the castle nut to spec. I don't want to cut corners, but I also don't want to spend money on something that one can really do without.
Thanks.
Idler arm J-29193 tool really necessary?
Jump to
- General
- ↳ Welcome New Members
- ↳ General
- ↳ Member Vans
- ↳ Camping & Outdoors
- ↳ Reviews
- ↳ Casual
- ↳ Events and Meet-Ups
- ↳ Marketplace
- ↳ Towing
- Chevrolet Astro, GMC Safari (1985 to 2005)
- ↳ Astro & Safari - General
- ↳ Engine
- ↳ STARTING ISSUES
- ↳ RUNNING ISSUES
- ↳ Starting/Charging system
- ↳ Exhaust System
- ↳ Cooling System
- ↳ Fuel System
- ↳ Air Intake
- ↳ NON-STOCK ENGINE SWAP
- ↳ V8 - SMALL BLOCK
- ↳ V8 - BIG BLOCK
- ↳ DIESEL
- ↳ DRIVETRAIN
- ↳ TRANSMISSION
- ↳ TRANSFER CASE
- ↳ REAR AXLE / DRIVE SHAFT
- ↳ FRONT AXLE / DRIVE AND CV SHAFTS
- ↳ Axle swap
- ↳ Chassis
- ↳ BRAKES
- ↳ STEERING
- ↳ SUSPENSION
- ↳ Lifting & Lowering
- ↳ WHEELS
- ↳ TIRES
- ↳ BODY
- ↳ INTERIOR
- ↳ EXTERIOR
- ↳ Climate Control
- ↳ TECHNICAL INFORMATION
- ↳ TECHNICAL
- ↳ ELECTRICAL
- ↳ AUDIO / VIDEO
- ↳ SECURITY
- ↳ Custom
- ↳ Off-Road
- ↳ Camperized
- Chevrolet Express, GMC Savana (1996 - Present)
- ↳ Express & Savana - General
- ↳ Body
- ↳ Lighting
- ↳ Towing and Hauling
- Chevrolet Van, G Series and GMC Vandura (1964 – 1996)
- ↳ G Van - General
- Website
- ↳ Announcements
- ↳ Feedback
