help before i burn it
captaincon
Post by captaincon »
After some advice my 92 safari is doing my nut .
It's slow to pick up and when I floor it it just dies so far it's had
Plugs ( old plugs was a nice colour)
Leads
Fuel filter
Coil
Complete distributor
Egr valve blanked
Cat removed
New exhaust
I have only had it about a month and it broke down on the way home .it had a fuel pump at 90000 Miles it's only on 93000 now .
Thanks for any help
WoodButcher
Been thanked: 18 times
Re: help before i burn it
Post by WoodButcher »
Have you checked the fuel pressure? New pumps in these vans fail too. If you pull the air cleaner you can watch the fuel spray.
Is the timing right?
Do you have the factory service manual? It helps for troubleshooting.
'93 cargo, work in progress
Post by doyoulikeithere »
is it a throttle body or a vortec engine? (VIN Z or W)
so, what happens when "it just dies"? is it hard to restart? can you smell fuel ? What ??
WoodButcher
Good catch, when was the vortec introduced?
captaincon
Thanks for the replys its a tbi .z code
No smell of fuel
It always starts easy
If I am easy on the throttle I can get it up to 70 but it has no power .
Its not cutting out or stalling.
It ticks over fine and will rev fine when it's not moving.
I agree woodbutcher.
Check both the inline fuel filter and the fuel pressure.
make sure the pump is providing enough pressure and be sure nothing is restricting the flow.
There is also a filter inside the tank that can plug up if the tank is real cruddy inside.
Also. is the engine light coming on? have you read the codes?
again, like WB said. the timing could also do it. if you have an egr blokoff then quite probably, your timing needs to be adjusted just slightly.
Do you know how to do that? you need to unplug the gizmo that sorta looks like a fuse from the distributor, and then shine the light. Zero is factory , and you probly need to advance it a few degrees is all. not too many. then it will have Oomph ! Maybe ;)
captaincon
Thanks guys will look in to it
WoodButcher
Pressure for the TBI is low, 9 - 11 pound I think is the factory set for the fuel pressure regulator.
Don't forget to look close at the distributor for play and the rotor and cap for wear. You said they were new but they don't last. My experience with both my vans has taught me to keep a cap and rotor for spares. I have new spares in both my '97 and in the '93. The heat in the doghouse of these vans just kills them. I put a new distributor in the 350 when I finished the swap in January, end of August the rotor was toast. I didn't use AC Delco but the Autozone premium, lifetime warranty. I put on my spare cap brought the old back and now have the new spare again. I'm sure the V8 being stuffed in w/ headers raised the temps under hood so I'm playing with a couple 120 mm fans, maybe they'll move the air a bit more but my plan is to get another hood, staking on the one I have to build a cowl induction type hood.
The '93 don't have a spare tire but I keep a spare cap,,, :-s
captaincon
Thanks all the above parts are a week old other than the fuel pump that has 3000 Mile on it .
I have ordered 2 New injectors + a rebuild kit I have also orderd a temp sender so fingers crossed
what is your timing set at?
what codes is it setting?
captaincon
0° on the timing
I am struggling getting the codes but i have a guy coming tommoz with some kit that may read it
WoodButcher
captaincon
That's very useful thanks I will have a play tomorrow
WoodButcher
I'm in the same boat with my 93' but I bought an ALDL cable to connect my laptop. Tuner Pro and Datamaster software is free but you can't do anything as to changes to the computer but you can get real time data.
http://www.gearhead-efi.com/Fuel-Injection/forum.php
