Lifting my new to me 95 safari on a budget and making it 4wd
Meterpig
Re: Lifting my new to me 95 safari on a budget and making it
Post by Meterpig » Tue Jan 06, 2015 7:33 pm
I am impressed and guessing you got the blown astro for a song given the parts cost. When you are finished...any plans for some killer paint schemes like matte black or camo? :guitar:
What do you think of my quest to swap transfer cases to the venerable BW4472?
viewtopic.php?f=58&t=9962
Photos including tear down for intake gaskets (PITA)
http://www.smugmug.com/gallery/n-xSjRG/i-bHzD6cz
akforceten
Post by akforceten » Sun Jan 11, 2015 3:16 am
Thank you Meterpig . Sorry no paint plans for now. I still got tons of work to keep me busy for a long time.Update just installed my new U bolts now i get to measure for rear shocks. Tomorrow i'm changing out the bushings an the ball joints in the control arms cause its time to rebuild the sub frame
1997 RWD Astro
1995 GMC Safari 4x4 lifted 5"
akforceten
Post by akforceten » Mon Jan 12, 2015 1:29 am
I was able to get some pics of the new U bolts so the rear leafs an shackles are done . I just need to find some a rear shock that's 23 3/4" long
these are made by Dorman part#35617
Auto zone shackles with home made bushing spacers
1997 RWD Astro
akforceten
Post by akforceten » Sun Jan 25, 2015 2:11 am
Update I have ordered rear shocks from rockauto.com there Monroe gas magnum shocks part #34687.
The compressed length is 18" The extended length is 31" for a total of 13"of travel. They should arrive here by the 29th . I also ordered prothane body bushing 7-108 BL . Tomorrow is ball joint an control arm bushing replacement day and of course building the 3" body spacers . i will be taking lots of pic's
1997 RWD Astro
Post by LiftedAWDAstro » Sun Jan 25, 2015 3:37 pm
Nice. Can't wait to see it! :bounce:
akforceten
Post by akforceten » Sun Jan 25, 2015 5:09 pm
Thank you it has been one awesome learning experience .I'm one who can never afford to buy a kit to do things so i have more fun doing it piece by piece from wrecking yards an using replacement parts from auto parts store
1997 RWD Astro
akforceten
Post by akforceten » Mon Jan 26, 2015 3:38 pm
Update - This weekend i spent removing upper an lower ball joints which was a blast loads of drilling Then i got to play with fire an melt all the bushing out of the upper an lower control arms. Then i used a body saw an cut out the metal sleeves an pressed in new moog runner bushing mounts so the control arms are done!.I also started cutting my 3"body spacers which i will get welded up next weekend . Ok picture time
fun drilling time
burning the bushings out
cutting my 3" body spacers
waiting to weld the top an bottoms on
ready for new bushing
new bushing installed
1997 RWD Astro
akforceten
Post by akforceten » Sun Feb 01, 2015 1:46 am
Update time I got my new rear shocks in an installed .Wow they really firmed up the ride . The rear lift is done except for the brake line needs to be lengthen. Ok pic time
part#
oh so pretty
Installed
rear lift done
1997 RWD Astro
Slicky
Post by Slicky » Fri Feb 06, 2015 1:53 pm
I have been enjoying your build , and am glad you elected to build your own leafs over using the lift blocks . With the new u bolts it looks very solid . Keep up the good work.
akforceten
Post by akforceten » Sat Feb 07, 2015 4:24 am
Thank you Slicky I didn't like the way the rear sat with one leaf pack almost flat . That is why i did my own leaf pack. i had to get rid of the lift blocks cause with my new leaf pack the rear of the van sat way to high. Now i feel things are better an stronger back there . This weekend im taking a break need to work on my 2000 astro
1997 RWD Astro
akforceten
Post by akforceten » Fri Apr 03, 2015 3:27 am
Update : I finally got my prothane body bushing today ! Also
my cylinder heads are done so i get to assemble some heads real soon and in a couple of weeks its going to be balls to the wall on weekends to get this project done!!!!!
1997 RWD Astro
akforceten
Post by akforceten » Mon Apr 20, 2015 1:15 pm
Update:Today I started to assemble the sub frame. I put new bushings and ball joints in the control arms.I also mounted the s-10 front differential and my re indexed torsion keys. I also got new CV axles but i spent like 2 hours trying to figure out why the left axle would bind up while i was tightening up the torsion key. it turned out it was the wrong axle in the right box. The part # matched on the box but the part was an inch to long okay pic time
wrong axle 1 inch to long causes it to lock up when torsion keys was tighten
Well that's it for now except going to the parts house an getting the right axle
1997 RWD Astro
SilverBullet1997
Post by SilverBullet1997 » Fri Apr 24, 2015 5:40 am
Wow, I just read through this whole thread, glad you were able to save a nice looking 95, and build it up to be something awesome
Here is a couple videos of my first van offroading at Tahuya WA.
http://www.youtube.com/watch?v=KkFaZXo2KL4
http://www.youtube.com/watch?v=D1zn5ppLI6g
R.I.P 1997 Astro AWD SilverBullet 4-9-1997 to 2-17-2015 - Cause of death: Rear-ended
1999 Astro AWD SilverBullet II 1-4-1999 - Present
5" lift, 31x1050r15 tires. 7 inches over stock
akforceten
Post by akforceten » Sun Apr 26, 2015 2:00 am
Thank you neighbor I'm bout an 8 hour drive from you i think. I also sourced just about most of the parts for the lift from the wrecking yard
1997 RWD Astro
SilverBullet1997
Post by SilverBullet1997 » Mon Apr 27, 2015 6:44 am
Well once you get done with the lift, maybe we can meet at one of the southern Washington ORV Parks, and go wheeling.
