It is currently Sun Aug 20, 2017 1:23 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: NP233 electric shift to manual shift swap
PostPosted: Tue Dec 18, 2012 9:48 pm
I want/need a true transfer case with low range so I decided to go with a NP233. Initially I wanted to use all the electronics and wire it in all proper like. After messing with and trying to figure out the wiring as none of the diagrams I found were the same, I decided to convert to manual shift. The reason I went with a 233 instead of a 231 is that all the 231's I have seen pics of have a yoke on the front output and with the 233, the stock drive shafts will fit with no mods.
Pulled the shift motor/encoder off...
 Post subject: Re: NP233 electric shift to manual shift swap
PostPosted: Wed Dec 19, 2012 9:03 am
Just for future reference on installing a low range switch for the PCM.
ASV link
PostPosted: Wed Dec 19, 2012 11:44 am
Started making the shifter pivot bushing assembly. I also ordered a cable and a couple rod end clevises for the cable. Going with cable shifted just like I did the SPB. It worked well and makes for only a single hole drilled through the floor.
This shoulder bolt will be bolted to the seat frame and have a shifter handle and cable linkage arm welded to it.
PostPosted: Wed Dec 19, 2012 11:08 pm
You can always use a 231 later....... they are better for doubling anyways :whistle:
Is this the start of the monster that I'm sure next year at some point I will see on the front of PBB and a vid on the powerblock?
Image 98 Safari RWD. Stock.
Do you smell what Barack is cookin ?!?!
PostPosted: Thu Dec 20, 2012 11:44 am
No plans for a doubler or for a SAS or any type of wheeling. I am hoping to lift it next spring but we'll see. My money is better spent these days on paying down our debt.
PostPosted: Thu Dec 20, 2012 7:18 pm
Got my cable and clevis rod ends today! 1 day shipping from McMaster-Carr! The cable is stock number 1338K21 and the clevises are stock number 1583K12.
PostPosted: Fri Dec 21, 2012 6:53 pm
Got a couple things done today...
PostPosted: Fri Dec 21, 2012 7:45 pm
Looks good, and the bonus is you probably can sell the module for the cost of the TC!
Gotta say I was disappointed you didn't go with the 242, but if a 233 would have been a no driveline mod to my '98 it would have been hard to resist.
4" lift, 31x10.50's, NP 242j/c hybrid, 4.10 gears, S10 front disconnect, trans cooler, rock sliders, bed and passenger swivel chair
PostPosted: Sat Dec 22, 2012 12:21 am
Very cool!
PostPosted: Sat Dec 22, 2012 12:32 am
The 242 would have been nice but I didn't want to spend the cash on the adapter and then modify the drive shafts. Hopefully I can build the rest of the cable mount and the shifter tomorrow.
PostPosted: Sat Dec 22, 2012 8:08 pm
Got the mount and shifter done! Gonna paint them Christmas while I am at work and will install the next week when I am off.
Welded up the cable mount...
Added the cable...
Finished the shifter...
Yeah, yeah...I know the van is a mess! :D Been raining here for a few weeks so there is a lot of dirt and mud in the van. Next nice day it'll at least get vacuumed out.
PostPosted: Sat Dec 22, 2012 10:49 pm
That is a great design. I plan to copy your idea for my 2003 AWD Astro next summer.
Thanks for great photos.
PostPosted: Sat Dec 22, 2012 10:58 pm
Go ahead and copy it! :supz: The hardest part (for me) is going to be pulling up the carpet so I can drill through the floor and mount the cable and then get the carpet back down and looking good.
PostPosted: Sat Dec 22, 2012 11:19 pm
you may be able to save yourself a lot of trouble by just mounting through the carpet and use a cover plate. Slightly different application in the photo, but I screwed the mount under the floor.I really didn't want to pull up the carpet!
PostPosted: Sat Dec 22, 2012 11:33 pm
I did that with the SPB and it worked good. I may do the same this time as the trim moulding screws are pretty rusty from salt.
Users browsing this forum: No registered users and 8 guests
cron
