That's a good reason! Ordered mine last night. Thanks!Marktainium wrote: I rechecked the catalog as I couldn't remember why I wouldn't have done that. Then I remembered. They quote different capacities, but the spring part numbers are the same.
DIY lift kit 2003 Safari
Re: DIY lift kit 2003 Safari
Any tips on rear spring installation, your axle looks pretty well centered, did you have to re-orient the front of rear hangers?
did you re-use the original leaf spring saddle mount, rubber isolators and u-bolt?
Cheers!
Cheers!
The rear leafs are a direct bolt in. I did have to shorten the leaf pack bolt or else it would have prevented the axle from seating onto the leaf properly. The leaf pack bolt is right in the middle of the leaf. It just has too much thread showing past the nut so I cut it down with a zip disk on a grinder. I'll try to do the full write up before the weekend. I re-used everything.
Well, you could have at least rolled your window down to take the pic....timelessbeing wrote:Look what I spotted on my way to work this morning ...
Stalker...timelessbeing wrote:Look what I spotted on my way to work this morning ...
Deja-Vu
I always try to capture the moment with my photos. I want you to see what I see LOL.mdmead wrote:Well, you could have at least rolled your window down to take the pic....timelessbeing wrote:Look what I spotted on my way to work this morning ...
Well I followed your instructions verbatim and this is the end result. I have no rubbing issues, alignment issues and the the van rides smoothly. It also helped to have a father who is a gun smith and had a lathe. Thank you. You saved me a ton of money with this forum and I could not be happier with the results! Hats off to you!
2003 Safari AWD SLT (Firefly)
4" lift, Rancho 5000 shocks
2" T6061 aluminum body spacers
S-10 leaf springs
Alpine stereo/Ipod/Ipad/Iphone
30" Maxxis 771 A/T Bravos
29 LX BT LCD CB Radio w/ Wilson 5000 short whip.
S-10 leaf springs
That's great! I'm glad it worked out. Looks good! I just finished installing my transfer case and wiring too, works awesome and almost looks stock... I'll write another thread on that too.
Now that you have some miles on the Van are you happy with the lift ? Is there anything you would change?
Bump , for those of you BC's lower mainland .The listed bolts on the first page are available through your local Fastenal store for $32 , although they need to order them in . North Shore Offroad sells the body lift blocks for $3.50 a piece so that's less than $25 for the set I now have everything I need for the lift except for the time to do it !
Doesn't take that much time and can be done in stages. Good luck and looking forward to see pictures and another lifted Astro in Metro VancouverSlicky wrote:Bump , for those of you BC's lower mainland .The listed bolts on the first page are available through your local Fastenal store for $32 , although they need to order them in . North Shore Offroad sells the body lift blocks for $3.50 a piece so that's less than $25 for the set I now have everything I need for the lift except for the time to do it !
2004 Astro AWD, 90k miles, 2" Lift, 225/75R16 Cooper Discoverer A/T3, Tru-Cool LPD-4490 Trans cooler
Why didn't you go with the '95-'05 Astro replacements? Would not give enough lift?photo_van wrote:
We have very close to the same overall miles re: idler arms. Thanks for the greasing tip.
I'm curious why you went with the s10 truck springs (1350#) rather than the s10 Blazer springs (1450#). Not a huge difference, but inquiring minds??? I've never been able to find a rating for my stock 2+1 springs, only 3+1 rated at 1410#s.
I rechecked the catalog as I couldn't remember why I wouldn't have done that. Then I remembered. They quote different capacities, but the spring part numbers are the same. I was happy with the ride quality of my stock springs, so didn't do the HD springs. I didn't want to need to wear a kidney belt when the van had no load in it. If I have a load issue I will turn to air bags or air shocks.
http://www.sdtrucksprings.com/leaf-spri ... /astro-van
The S 10 springs have ~3" more arch than the Astro springs, so ~3" of lift....
