Over heating problem please help!!
Rebel
Location: Evergreen, Al. 96 mile marker, where life is slow and there are no rules.
Re: Over heating problem please help!!
Post by Rebel » Tue Dec 27, 2011 9:22 pm
Are you relying on the temp gauge only or have you hooked up a mechanical gauge to verify your gauge is correct ?
89 Astro, 350 V-8, Shaved doors, Filled Slider, Corvette IRS, 94 Mustang GT Rack & Pinion(Thanks to Skip),
VIDEO
If you drive illegally, they take your driver's license. If you're here illegally, they want to give you one :)
If guns kill people, do pencils misspell words
MrJames
Post by MrJames » Wed Dec 28, 2011 1:31 am
Did this problem exist before the work (intake manifold gasket, thermostat and temp sender) or started after ?
timelessbeing
Post by timelessbeing » Wed Dec 28, 2011 2:35 am
I assume your water pump is healthy?
Derek939
Post by Derek939 » Wed Dec 28, 2011 5:15 pm
Mrjames- before I replace the intake gaskets and thermostat and sender my van didn't have a thermostat in it so it ran cold until I started to climb a hill then it would climb up to the yellow. After all that work it would sit at an idle an over heat but if you started driving it would cool down. Soooo, I replaced my radiator and cap last night and it is
Running cooler then I've seen it run. I still have not drivin it enough up and down some hills and I'll know if it's working or not! And I believe my water pump is healthy because it is not leaking yet. I'm hopeful this radiator has solved my issue!!!
1991 Astro RWD EXT w/187000 miles
1991 GMC safari RWD shorty w/151000 miles
Runs off of Bacon!
The revolution of the Maing Bus!!!
Derek939
Post by Derek939 » Sat Dec 31, 2011 2:33 pm
I believe the radiator has fixed my problem. I'm wondering why I keep flashing a code 32 though?
Runs off of Bacon!
sfeaver
Post by sfeaver » Sat Dec 31, 2011 4:32 pm
That is an EGR code. What engine do you have? There are two different styles of EGR valve. Check for the connections, and the vacuum lines being hooked up.
Scott
Derek939
Post by Derek939 » Sun Jan 01, 2012 2:59 am
I've got the 4.3 vin z I think. I only say I think because I have recently learned its not the original engine but it is a 4.3 and it has the transmission out of a 93 Camero. I'll pull the dog house tomorrow but the EGR valve will be on the drivers Side under the dog house right?
Thanks,
Derek
Runs off of Bacon!
