Flushing cooling system
Topic author - I have my van tatooed on my cheeks
I'm thinking of installing a flush kit. The kind where you splice in a 'T' for attaching a garden hose. Anyone know the size of the hose going from the heater to the pump?
Also, out of curiosity, are there any cooling system diagrams out there?
Re: Flushing cooling system
NOOOOOOOOOOOOOOOOOO! DO NOT CUT ANY COOLING LINE! It only leaves more places to leak. Besides, this topic has just recently been discussed in these forums.
The topic is: viewtopic.php?f=6&t=5737
Mike, Billings, MT, 'MERICA!
98 AWD Stro LS
93 Suburban Silverado 4x4
98 AWD Stro LS
Why would it leak? Even if it did, it's very easily accessible.
It's a good point about the thermostat not opening though. I could always yank the hose off the radiator to drain it, and the hose from the rear heater to drain that, although that's what I was trying to avoid. Or better yet, I could T into the radiator hose. The question is, does idling generate enough heat to keep the t-stat open long enough.
Again, I refer you to the other topic already existent. Why cut lines when you don't have to?
98 AWD Stro LS
98 AWD Stro LS
To make the process easier and quicker. But there's no easy way to do it, is there? You either have to unplug several hoses, or do several flushes.CaptSquid wrote:Again, I refer you to the other topic already existent. Why cut lines when you don't have to?
You catch on quickly.
98 AWD Stro LS
98 AWD Stro LS
So the cooling system capacity is 16L. That means I'll need 8 to 10 L of coolant. Anyone know the capacity of just the radiator?
- Has thanked: 2 times
I believe the tech section at autozone.com has all these stats online.timelessbeing wrote:So the cooling system capacity is 16L. That means I'll need 8 to 10 L of coolant. Anyone know the capacity of just the radiator?
1998 Astro, 246,000 miles
This is all it says on Autozone
The Cooling System Mix
1 3/4 Gallon (s) of Full Strength Anti-Freeze
Application:
Without rear heater
Specification amount is for a 50/50 ratio mix in the cooling system. If using pre-mixed anti-freeze double the amount needed.
Maybe try looking up a replacement radiator, sometime they list the capacity of said part.
I don't know those weird L measurements...
But the radiator will only hold between 1 and 2 gallons. So if you mix 50/50, 1 gallon of antifreeze will net 2 gallons with water. That would be enough to fill it up if you drain just the rad. You could always buy 2 gallons of AF and just store the remainder for later use.
Side note...I always mix 2/3 AF and 1/3 water since 70/30 is too hard to figure out. I pour 2 gallons of AF and 1 gallon water into a bucket and then whatever is left is marked 70/30 on the jug and placed in the cabinet for storage. You could also carry it in your van if you carry a supply of lubes and parts in a tool kit.
OK so it sounds like after a complete drain, I can dump 2 gallons of AF into the rad, and then top up the rest with water. Easy.
Litres are actually pretty cool. You get to work with numbers that are really easy to remember, understand and do math with:
* 1 litre H20 = 1 kg
* 1 litre = 1000 cubic centimeters
* 1.234 litres = 1 234 millilitres
The imperial conversion are easy enough
1 litre ~ 1 quart
4 litres ~ 1 gallon
1 litre ~ 1 quart
4 litres ~ 1 gallon
I was flushing the cooling system, and noticed a disconnected electrical plug. It's on the same loom as the windshield fluid pump, and it has a red rubber seal (most are blue).
Anybody know what this is for?
