The long list of RPO codes.
WIN-ALDL, PROM BURNING, ERROR CODES, RPO CODES, SES LIGHT, CHECK ENGINE LIGHT, VIN INFO, FACTORY INSTALLED OPTIONS LIST
v8famvan
Post by v8famvan »
Here is a long list of RPO codes specifically for the Astro/Safari vans. (not all the engines listed here were available)
This will be added to as I find them. Please PM me with missing RPO codes & they will be added.
RPO Codes.
AB2 Window: Side Body, Stationary, Left Side
AC3 Adjuster, Front Seat, Power, 6 Way, Bucket, Driver
AG1 Seat Adjuster: Power, 6-way, Driver
AG2 Seat Adjuster: Power, 6-way, Passenger
AJ1 Windows: deep Tint, all Except W/S and DRS
AK9 Restraint System, Rear Seat, Shoulder, Retractor, 3 point
AL4 Seat: Rear Bucket
AN0 Seat Adjuster: Manual, 6-way, Lumbar, Driver and Passenger
AN5 Seat: Child, Integral, Dual
AN6 Seat Adjuster RR Intermediate Seat, Manual, Lumbar
AP2 Restraint: RR Shoulder Belt, Anchor, Delete
AP9 Net: Convenience
AQ4 Seat: Rear
AR1 Restraint System: Delete
ATZ Rear Seat - Delete
AU0 Lock Control: Remote Entry
AU3 Lock Control: Side Door, Electric
AU5 Lock Control Remote Entry, Low Power
AV5 Seat: Front Bucket, High Back
AXP VIN Identification, Position, Multi-Purpose Vehicle
A07 Window: Body
A08 Window: Body, Right Side
A12 Window: Rear, Stationary, Back Door
A13 Window: Side Door, Stationary
A18 Window: Rear Door, Swing Out
A19 Window: Rear Side Door, Swing Out
A31 Window: Power Operated, Side
A57 Seat: Passenger, Auxiliary, Folding
A78 Seat Back Adjuster: Front, Manual, Drivers & Passenger Reclining
BAG Parts Package: Export
BAL Plant Code: Baltimore, MD, GM T&B
BA1 Ornamentation, Extra Hood
BA8 Compartment: Front Seat, Stowage, Passenger
BVE Running Boards: Side
BX2 Molding: Body Side, Lower, Extra Wide
B30 Covering: Floor Carpet
B37 Covering: Floor Mats, Front & Rear, Auxiliary
B39 Covering: Floor Carpet, Load Floor
B74 Molding: Wheel Opening, Extra Wide
B84 Ornamentation, Extra Moulding, Body Side
B88 Molding: B/S Custom
B94 Ornamentation: Extra Emblem
CTF Next Generation Air Bag
C04 Roof, Covering Vinyl Padded Rear
C1U Fleet Incentive, Enterprize Rent-A-Car
C1W Fleet Incentive, Dollar Rent-A-Car
C36 Heater: Auxiliary
C4F GVW Rating 5,900 lbs
C49 Defogger: Rear Window, Electric
C5G 5600 Lbs. GVW Rating
C5M 6100 Lbs. GVW Rating
C6M 5950 Lbs. GVW Rating
C60 HVAC System, Air Conitioning Front Manual Controls
C69 Air Conditioning: Rear
C7X 5850 Lbs. GVW Rating
C95 Lamp: Interior, Roof, Courtesy and Dual Reading
DH2 Mirror: I/S, Front Vanity LH & RH , Illum., with Dual Sunshade
DH6 Mirror: I/S, Sunshade, Illum., LH & RH
DK6 Console: Roof, Interior
DK8 Console: Roof Interior, Deluxe
D34 Mirror: Inside, Sunshade
D44 Mirror: Outside, Painted
D48 Mirror: Outside, Remote Control, Electric, Painted
EB6 GVW Rating 6050 lbs
EVA Test DVT, EVAP Emission Requirement
EXP Export Processing Option
E54 Body Equipment: Rear Door, w/End Gate Window
FE2 Suspension: System Ride, Handling
FE9 Certification: Emission, Federal
FG3 Shock Absorbers: Front & Rear, Gas
F0F Fleet Incentive Tourism Industry Inc. DBA Budget Sales & Leasing
F51 Shock Absorbers: Front & Rear, Heavy Duty
F61 Stabilizer Shaft: Rear
GQ1 Axle: Standard Ratio
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4:10 Ratio
GU5 Rear Axle: 3.23 Ratio
GU6 Rear Axle: 3.42 Ratio
G50 Spring Rear: Heavy Duty, Var 1
G80 Rear Axle: Positraction
JB3 Brake, Power, Disc/Drum, 4600 Lbs
JH1 Hydraulic Brake Power, Disc/Disc, 6400 lbs
JM4 Brake System: Power, Front Disc, Rear Drum, Antilock Front & Rear
K05 Heater: Engine Coolant
K34 Cruise Control: Automatic, Electronic
K53 Fuel Sender, Robust Fuel System
K55 Fuel Sender Assembly: Low Lubricity
K60 Generator: 100 Ampere
K68 Generator: 105 Ampere
LB1 Engine Gas, V6, 6 Cyl, 4.3L, 4BBL (VIN code 'N')
LB4 Engine Gas, V6, 6 Cyl, 4.3L, TBI (VIN code 'Z')
LN8 Engine Gas, L4, 4 Cyl, 2.5L, TBI (VIN code 'E')
LO3 Engine Gas, V8, 8 Cyl, 5.0L, TBI (VIN code 'H')
LO5 Engine Gas, V8, 8 Cyl, 5.7L, TBI (VIN code 'K')
LU3 Engine Gas, V6, 6 Cyl, 4.3L, MFI (VIN code 'X')
L30 Engine Gas, V8, 8 Cyl, 5.0, CPI (VIN code 'M')
L31 Engine Gas, V8, 8 Cyl, 5.7, CPI (VIN code 'R')
L35 Engine Gas, V6, 6 Cyl, 4.3L, CPI (VIN code 'W')
MD8 Transmission, Auto 4 Speed, THM 700R4
ML3 Transmission, 5-speed manual
MPV Multi-Purpose Vehicle (AKA Money Pit Van)
MR2 Transmission, 4-speed manual
MX0 Merchandised, Trans, Auto Provisions, O/D
M1J Lamp Fog, RR Additional
M30 Transmission: Hydra-Matic 4L60-E, 4-Speed Automatic, Electronic
NA3 Emission System: Japan
NA5 Emission System: Federal, Tier 0
NB7 Emission System: California, TLEV
NB8 Emission Override: California System
NC1 Emission System: California, LEV
NC7 Emission Override: Federal System
NC8 Emission System California ULEV
NF2 Emission System: Federal, Tier 1
NF4 Emission System: Clean Fuel Fleet
NF7 Emission System: Federal, NLEV
NG1 Emission Certification: Geographically Restricted Registration
NM2 Emission System: Export
NM8 Leaded Fuel System Compatible
NN8 Emission System: Override Unleaded Fuel, Export
NP4 Transfer Case Active All Wheel Drive (AWD) Single Speed
NP5 Steering Wheel: Leather Wrapped
NT9 Emission System Federal, Tier 2 Phase-Out
NU4 Emission System California LEV2 Plus
N12 Exhaust System: Rear Exit
N31 Steering Wheel: Custom
N33 Steering Column: Tilt Type
N40 Steering, Power, Non-Variable Ratio
N46 Steering Wheel: Four Spokes
PA6 Wheel: Styled, Painted
PC2 Wheel: 15 x 6.5, Chrome, Styled
PF3 Wheel, 15 x 6.5, Aluminum
PF4 Wheel 16 x 7, Aluminum
PF9 Wheel 16 x 7, Aluminum Cast
QCG Tire: All, P205/75R15/N WS2 R/PE ST TL ALS
QCM Tire: All, P215/75/R15 WOL R/PE ST TL ALS 100S
QCU Tire: All, P215/75/R15/N BL R/PE ST TL ALS
QCV Tire: All, P215/75/R15/N WS2 R/PE ST TL ALS
QPZ Tire: All, P235/65/R15 WOL R/PE ST TL AL2 100S
QRD Tire All P215/70R16-99S BW PE/ST TL ALS
QTP Tire All 215/70R16-100T BW PE/ST TL HWY
RSA Restraint: Front Seat, 208, Auto, Passive
RSB Restraint: Front Seat, 208, Auto, Active
R4L Tire Brand Front: Michelin
R6H Control Sales Item No. 8
R6Q Control Sales Item No. 16
R7K Control Sales Item No. 36
R7Y Control Sales Item No. 49
R8K Control Sales Item No. 61
R8S Control Sales Item No. 68
R9Z Control Sales Item No. 100
S4L Tire Brand Rear: Michelin
SLM Stock Order Processing Code
TAK Fleet Sales Early Order Incentive
TFD Retail Amenity Delete
TL1 Grille: Special
TR2 Lamp Turn Signal: Enlarged
TR8 Reflector Warming, Disabled Vehicle
TR9 Lamp, Group
T62 Lighting: Daytime Running, Delete
T72 Left Hand Headlamps, Rule of the Road
T84 Headlamps: RH Rule of Road, E Mark
T85 Headlamps: LH Rule of Road, E Mark
T89 Lamp: Tail & Stop, Export
T90 Lamp: Front Turn, Export
UA1 Battery, Heavy Duty
UA6 Theft Deterent System
UC2 Speedometer: Instrument, Kilo & Miles, Kilo Odometer, Positive Bias
UD4 Alarm: Vehicle Speed, 120 KPH
UG1 Opener: Garage Door, Universal
UK1 Radio: Frequencies, Japan
UK6 Radio Control: Rear Seat & Earphone Jacks
UL0 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse Cassette, Music Search
UL2 Radio: Frequencies, Europe
UL5 Radio: Delete
UL8 Saudi Arabian Frequencies
UM6 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse Cassette, Clock, ETR
UM7 Radio: AM/FM Stereo, Seek/Scan, Clock, ETR
UN0 Radio: AM/FM Stereo, Seek/Scan, Compact Disc, Auto Tone
UP0 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse, Music Search, Cassette, Compact Disc Player, Auto Tone
UQ1 Radio Provisions: For Stereo
UW3 Radio: AM/FM Stereo, Seek/Scan, Auto Reverse, Music Search
UX1 Radio Provision, For Stereo
UY7 Wiring Harness: Trailer, Heavy Duty
U19 Speedometer: Instrument, Kilo & Miles, Kilo Odometer
U37 Lighter Cigarette
U73 Antenna: Fixed, Radio
VAJ Package: Roadside Service Program
VB1 Label Shipping, Japan
VC4 Label Price/Fuel Economy, Puerto Rico
VC5 Label Shipping, Except US, US Possessions, or Japan
VC7 Label Price/Fuel Economy, Guam
VE1 Provision: Options, Japan
VE6 Bumper: Front & Rear, Impact, Painted
VG8 Label: Vehicle, Notice to Buyer
VJ1 License Plate: Rear Mounting Pkg, Japanese
VK3 License Plate: Front Mounting Plate
VK5 Seat: Temporary, For Shipping
VLS Label, VIN Secondary, Vehicle Identification Number
VL6 License Plate: Front Mounting Pkg, Japanese
VN9 Jack, Mechanical
V02 Radiator, Heavy Duty, With Transmission Oil Cooler
VPH Vehicle Preparation: Overseas Delivery
VP6 Noise Control
VQ2 Fleet Program, Dealer assistance, Holdback Not Applicable
VR4 Trailer Hitch: Weight Distributing Platform
VR6 Hook: Tie Down
VT3 Bumper: RR Export
VXS Vehicle: Complete
VXT Vehicle: Incomplete
VX5 Bumper: Component
V10 Provisions: Cold Climate
V54 Luggage Carrier: Roof, Painted
V73 Vehicle Statement: US/Canada
V78 Vehicle Statement: Delete
V87 Vehicle Statement Gulf States Organization
V98 Factory Delivery Processing
WX7 Wiring Provisions
XCM Tire: Front, P215/75/R15 WOL R/PE ST TL ALS 100S
XCU Tire: Front, P215/75/R15/N BL R/PE ST TL ALS
XCV Tire: Front, P215/75/R15/N WS2 R/PE ST TL ALS
XPZ Tire: Front, P235/65/R15 WOL R/PE ST TL AL2 100S
XRD Front Tire P215/70R16-99S BW PE/ST TL ALS
XTP Front Tire 215/70R16-100T BW PE/ST TL HWY
X88 Conversion Nameplate: Chevrolet
YA7 Test: Emission, California Assembly Line
YB9 Paint: Interior, Delete
YCF Tire: Rear, P205/75/R15 ALS RWL
YCM Tire: Rear, P215/75/R15 WOL R/PE ST TL ALS 100S
YCU Tire: Rear, P215/75/R15/N BL R/PE ST TL ALS
YCV Tire: Front, P215/75/R15/N WS2 R/PE ST TL ALS
YC5 Convenience Package: Decor Level #5
YC6 Convenience Package: Decor Level #6
YC7 Convenience Package: Decor Level #7
YD3 Axle: Base Equipment
YD5 Spring: Front, Base Equipment
YD6 Spring: Rear, Base Equipment
YF5 Emissions: California
YF7 Sales Package: Recreational Vehicle Upfitter
YG6 HVAC System: Air Conditioning, Not Desired
YPZ Tire: Rear, P235/65/R15 WOL R/PE ST TL AL2 100S
YRD Rear Tire P215/70R16-99S BW PE/ST TL ALS
YTP Rear Tire 215/70R16-100T BW PE/ST TL HWY
ZA6 Package Price Leader
ZA7 Package Price Leader: Canadian
ZP0 Seating Arrangement: Temporary Driver
ZP5 Seating Arrangement: Five Passenger
ZP7 Seating Arrangement: Seven Passenger
ZP8 Seating Arrangement: Eight Passenger
ZQ2 Sales Package: Driver Convenience
ZQ3 Sales Package: Driver Convenience II
ZW2 Window Package: Rear Doors
ZW3 Window Package: Side Rear Door, Rear Doors
ZW6 Window Package: Complete Body
ZW9 Body Equipment: Base Body or Chassis
ZX2 Seating Arrangement: Driver & Passenger, Highback
ZY1 Color Combination: Solid
ZY2 Color Combination: Two-Tone
Z31 Identification: Price Sheet Advantage
Z49 Base Equipment: Canadian Mandatory
Z5X Mirror Provisions, Arabic Language
Z82 Trailering Provisions: Special Equipment, Heavy Duty
Z88 Conversion Nameplate: GMC
O1U Primary Colors Exterior, Special, (91)
05U Primary Color: Exterior, Cyclamen Metallic
1SA Package Option 01
1SB Package Option 02
1SC Package Option 03
1SD Package Option 04
1SE Package Option 05
1SF Package Option 06
1SG Package Option 07
1SH Package Option 08
1SJ Package Option 09
1SK Package Option 10
1SL Package Option 11
1SM Package Option 12
1SN Package Option 13
1SP Package Option 14
1SQ Package Option 15
1SR Package Option 16
1SS Package Option 17
1ST Package Option 18
1SU Package Option 19
1SV Package Option 20
1SW Package Option 21
1SX Package Option 22
1SY Package Option 23
1SZ Value Group Savings
1TB Option Group Selection: Package #1
1TC Option Group Selection: Package #2
1TD Option Group Selection: Package #3
1TF Option Group Selection: Package #5
1TG Option Group Selection: Package #6
1TH Option Group Selection: Package #7
1TJ Option Group Selection: Package #9
1TK Option Group Selection: Package #10
1TM Option Group Selection: Package #12
10Q Molding Color: Ghost White
10U Primary Color: Exterior, Ghost White
14U Primary Color: Exterior, Storm Gray Metallic
15P Wheel Color: Silver Metallic
15Z Interior Trim: Vinyl, Slate Gray
16U Primary Color: Exterior, Warm Gray Metallic
17A Stripe Color: Accent, Silvermist
17Q Molding Color: Silvermist Metallic
17U Primary Color: Exterior, Silvermist Metallic
2CU Tire: Front P215/75R15/N BW R/PE ST TL ALS
25U Primary Color: Exterior, Cadet Blue Metallic
26G Trim Combination: Cloth, Navy (G)
26I Interior Trim: Navy (I)
26W Trim Combination: Vinyl, Navy (W)
3CU Tire: Rear P215/75R15/N BW R/PE ST TL ALS
36Q Molding Color: Medium Dark Teal Metallic
36U Primary Color: Exterior, Medium Dark Teal Metallic
47G Trim Combination: Cloth, Dark Red
47I Interior Trim: Dark Red
5CU Tire: All P215/75R15/N BW R/PE ST TL ALS
52G Trim Combination: Cloth, Light Neutral (G)
52H Trim Combination: Cloth, Medium Neutral II (H)
52I Interior Trim: Light Neutral (I)
52W Trim Combination: Vinyl, Light Neutral (W)
522 Trim Combination: Leather, Light Neutral (2)
53A Stripe Color: Accent, Medium Gold Dust
53Q Molding Color: Light Toreador Red Metallic
53U Primary Color: Exterior, Light Toreador Red Metallic
55A Stripe Color: Light Autumnwood Metallic
55Q Molding Color: Light Autumn Wood Metallic
55U Primary Color: Exterior, Light Autumn Wood Metallic
56A Stripe Color: Accent, Light Agate
57Q Molding Color: Forest Green Metallic
57U Primary Color: Exterior, Forest Green Metallic
59U Primary Color: Exterior, Red Maple II Metallic
6UA Component: Front LH Computer Select Suspension
6UB Component: Front LH Computer Select Suspension
6UC Component: Front LH Computer Select Suspension
6CT Component: Front LH Computer Select Suspension
6XB Component: Front LH Computer Select Suspension
60A Stripe Color: Accent, Gold Metallic
69Q Molding Color: Copper Metallic
69U Primary Color: Exterior, Copper Metallic
7CT Component: Front RH Computer Select Suspension
7UA Component: Front RH Computer Select Suspension
7UB Component: Front RH Computer Select Suspension
7UC Component: Front RH Computer Select Suspension
7XB Component: Front RH Computer Select Suspension
75U Primary Color: Exterior Briliant Red Metalic
76A Stripe Color: Accent, Dark Bronzemist
76Q Molding Color: Dark Bronzemist Metallic
76U Primary Color: Exterior, Dark Bronzemist Metallic
77G Trim Combination: Cloth, Dark Maple (G)
77I Interior Trim: Dark Maple (I)
79G Trim Combination: Cloth, Ruby Red (G)
79I Interior Trim: Ruby Red
79W Trim Combination: Vinyl, Ruby Red (W)
8R1 Headliner, Delete
92G Trim Combination: Cloth, Medium Dark Pewter
92H Trim Combination: Cloth, Medium Dark Pewter
92I Interior Trim: Medium Dark Pewter
92W Trim Combination: Vinyl, Med Dark Pewter
922 Trim Combination: Leather, Medium Dark Pewter (2)
James from B.C.
1992 Safari - R.I.P.
GM Grand Master Techncian
astrozam
Been thanked: 2 times
Post by astrozam »
Rileysowner
Post by Rileysowner »
Well, that is a wonderful list that certainly will help in figuring out what a van one it looking at had in it from the factory. Thanks!
ihatemybike
Re: The long list of RPO codes.
Post by ihatemybike »
Great post!
Aaron
Prev Astros:99,97,00,94,87,86
moboman
Post by moboman »
What did you have to do in order to get a stock v8? Was that the government model?
astrozam
Post by astrozam »
moboman wrote:what did you have todo in order to get a stock v8? Was that the government model?
The men in black drove those,lol
Never offered to the public.
GM RPO Codes
Here is a link to a site that has all the RPO codes for the GM products. For the front and rear differentials you are looking for the GUx, GTx and G80 codes. You will find the RPO tags on your van in either the glove box or on the passenger door jamb.
Cobra
Re: GM RPO Codes
Post by Cobra »
you know i went hunting for that sticker on a 2004 awd and couldn't find it.. i may just be blind tho
G3500 front calipers
Zexel Torsen Diff
11" drums
180 amp Alternator
1997 gone
ihatemybike
Re: GM RPO Codes
Should be on the passenger side door.
Aaron
slim724
Re: Mystery RPO codes
Post by slim724 »
I got some of the codes from the "long list of RPO codes" stckied above, and I got most from a link I found here but of course I can't find the thread or link sorry, it was a link to GM RPO codes for trucks, vans and had most of the codes there
1999 Astro 7-Passenger Van
Federal Government Fleet Vehicle
Cadet Blue 4.3L V6
Rear A/C & Heat
RWD G80 posi with 3.42 gears
40,000 miles
slim724
Post by slim724 »
I found the link for GM codes, the option lists are on the left of the page by alphanumerical order, hope this helps
http://www.c2e.info/rpocodes/
Cadet Blue 4.3L V6
Rear A/C & Heat
40,000 miles
slim724
Post by slim724 »
I was just going to assume that FLT means fleet vehicle since it was formerly a federal government fleet vehicle, good to know what the AXP means, on my drivers side door sticker, after the VIN, it says TYPE: M.P.V. do all vans say this??
Cadet Blue 4.3L V6
Rear A/C & Heat
40,000 miles
slim724
Post by slim724 »
Haha, yes I'm 100% sure it means Multi Purpose Vehicle, I was just wondering if all Astro's/Safari's were categorized as that on their door sticker
Cadet Blue 4.3L V6
Rear A/C & Heat
40,000 miles
Post by Smiliesafari »
With all of the mods we do it could mean "Money Pit Vehicle". \:D/
markmitchinnh
RPO codes sheet? 2001 safari
Post by markmitchinnh »
I am getting parts from a 2001 safari but I have no idea where the rpo code sheet is located on this year. Anyone know?
