Ok, did some more research, and I printed out the circuit descriptions and diagrams at work to share with you all. I wrote a simple diagram for the switch. There is one for 96-00 and one for 01-05.
Enjoy!
Intalled NP231C 4LO Range switch wiring
Re: Intalled NP231C 4LO Range switch wiring
Brandon
Bay City, MI
1997 Astro LT 4x4 48,000 Miles,
Custom Lift: 3" body spacers, torsion keys,
4" leaf spring relocation mounts (by ME),
added a leaf spring from a 94 S10 blazer.
All this gives me 5-6 inches of lift.
General Grabber AT2 31X10.50R15
Custom fit Brush guard
Western 7' 6" plow pictures coming soon...
1997 Buick Century 198,000 miles
Bay City, MI
Good stuff...
Congradulations, and thanks for the info Brandon
This works w/o a TCCM right? Can anyone point me to connector 4, terminal 23 of the PCM on my '98???
Great info, thanks
Great info, thanks
ok, this helps
"ECU, ECM, PCM, VCM ... all abbreviations for the same thing.".
The PCM is mounted right beside the battery. Not sure which connector is C4 and yes it will work without a TCCM since your 98 doesn't have one.
Thanks. I was looking for a PCU all thru the manual to no avail, ECU on the other hand.... . I should be able to wire it directly to the low range terminals on the tc selector switch.
This seems like a HUGE improvement, glad to have stumbled upon it.
keep us posted photo_van i would like to see how this turns out... w/pics of course
99 astro awd ls package, 3" bodylift, alarm system w/remote start, tinted windows, tranny cooler, modded air intake, bigger power steering cooler, hood struts, westin pushbar, hypertech tuned running on 91 octane, Hypertech 160* thermostat, 1 ton calipers and pads (not much of a difference as i expected)30" tall tires 245-65-17 on jeep wheels
here is a link to my pics: http://s795.photobucket.com/home/unrreal/allalbums
Will do. I've got the NP 242C built and waiting in the shed (and pics in the computer). Just need the van to quit breaking so I have time to install!
Conector 4 is the BLACK one on the VCM according to the manual.
Here's the end view Terminal 23 should be unused
