91 safari awd..speedo stays at 0... most likely cause?
ANYTHING TO DO WITH MAKING YOUR VAN MOVE EXCEPT FOR THE ENGINE ITSELF.
Gordon
Post by Gordon »
Just go this van home today. The speedo was working when i picked it up but died on the way home.
What do you figure it is?
A) Battery is stone dead and had to be boosted?
B) VSS?
C) Wiring?
D) Digital dash issues?
Thanks in advance,
Gordon
1995 GMC Safari 5.7L RICE EATER... MUHAHAHAHA
91AWDAstro
Re: 91 safari awd..speedo stays at 0... most likely cause?
Post by 91AWDAstro »
If you have high miles on the van, I would take the cluster out and take it apart. Look for cold solder joints. I had a lot on mine causing a couple of the gauges not to work.
I don't understand all I know about that.
Chris
91AWD 350
and a bunch of other wrecks...
Gordon
Post by Gordon »
237,000 kms so not really high but I will check the gauges to start.
zook94
Post by zook94 »
every once in a while mine will stick at zero. my solution which has always worked, is to slap the top of the dash with my left hand. my speedo always jumps to life after therapy.
http://www.misfitoffroad.com
'93 EXT 2wd 5.0 (for now)
91AWDAstro
That symtom definately sounds like cold solder joints.
Chris
91AWD 350
