Hitch for '03 Cargo
Dayne66
Hitch for '03 Cargo
Post by Dayne66 »
Looking at hitches:
https://www.amazon.ca/Reese-Towpower-06 ... 34&sr=8-25
https://www.amazon.ca/Reese-Towpower-51 ... 47&sr=8-27
and
https://www.amazon.ca/Draw-Tite-75122-M ... 34&sr=8-39
Looks like either will fit.
Will a full sized spare still fit underneath?
Do either stick out past the bumper to be a potential knee-knocker?
Does one 'tuck up' better...less of a chance of it getting caught on debris or a 'mound'?
Thanks in advance for any input!
Re: Hitch for '03 Cargo
Post by Captn. Crunch »
The first hitch you linked to has a bow to it that will match the curve of the rear bumper if that’s important to you but the other two have twice the frame mount surface and that’s a notable difference. The receiver on mine is tucked under the bumper cover and poses no obstacle. I never remove the hitch from the receiver so yes it will get a shin if you aren’t careful. A full sized tire will fit. I just put new tires on my 03 and the 235/75r-16 spare cradled right up with no issues
Dayne66
Post by Dayne66 »
Thanks!
The one that's got a bow to it also has some other 'tabs' on it...maybe to attach to the bumper mount bolts for added support to make up for less frame mount points....am I correct?
Exactly right. Either way you will be fine. I can’t recall anyone ever tearing their hitch off their van. Just make sure to re-torque your hardware after your first use.
Bret Schmerker
Post by Bret Schmerker »
:bounce: I did some advance research on receivers for my M11006 and found two acceptable models offered by etrailer®. Ye know about the DRAW-TITE® Model 75122 (3500# gross / 350# tongue weight-carrying; 6000# gross / 600# tongue weight-distributing), incidentally my first choice on fit for an extended-length M-body. But additionally, CURT® has an optimum-strength, alignable offering in their Model C13035 (4000# gross / 400# tongue weight-carrying; 6000# gross / 600# tongue weight-distributing). Both use four M12-1.25 flange bolts, Class 12.10, on each side to attach to the unit body abaft the powertrain frame. Be advised that the C13035 is sized for standard-length M-bodies and may prevent tucking a 215/75R15-shod rim under the body on the stock spare-tire winch.
