Phantom Rebel V8 Swap
Moderator: mdmead
AquaAngel
Post by AquaAngel » Tue May 15, 2012 4:24 am
decided to make a post for it on my progress instead on going on my facebook page.
Motor when i got it. ugly
few layers of paint
freshly done, need more parts like timing kit and rear main seal, but over all, almost done
My new Intake with power-aid
New Exhausts
More pics coming up once i get the rest of my parts as i am still looking for the down pipe or Y pipe for it. my other oil pan is already painted and will be put on as soon as my rear main seal gets replaced.
looking forward to see this bad girl with a V8. actually dying for it.
Also forgot to mention that She will also get a 2" lift, rest of the suspension kit is yet to see. looking forward how she will look like when all this is done. and next year? body shop for a paint job
Chevy owned:
98 GMC Safari AWD
AquaAngel
Re: Phantom Rebel V8 Swap
Post by AquaAngel » Tue May 15, 2012 4:34 am
The only other issue that i have with this conversion is also to re-route my PCV valve and the other line that goes in the TBI system and might have to extend my oil filler neck, SO if you have any ideas to get around it? I am open for suggestions.
Just because the new Valve cover is and totally is different than my Astro's configuration, does the PCV valve makes any difference as of where it should be located?
as of now, on the Astro? it is located on the Passenger side, would it matter if it is on the driver side?
How about the tbi part of it? does it matter if it is on the passenger side instead of the driver side?
Chevy owned:
98 GMC Safari AWD
Post by doyoulikeithere » Wed May 16, 2012 7:44 pm
Looks Greaqt AquaAngel.
If ya need any parts, I'm not far from you, and have a fair amount of Gen1 parts.
I have some extra 2" blocks for lifting the rear,
and I have a set of brand new unused from OLV, Lift Coil Springs for about 1.5 inches of lift to the front of a 2wd van.
HotrodDaddy43
Post by HotrodDaddy43 » Wed May 16, 2012 9:31 pm
hey what are those headers? and Ford blue? jk nice start.
AquaAngel
Post by AquaAngel » Sat May 19, 2012 3:17 pm
Ford Blue, yup, i know, i will give a different name. Chevy blue. sounds better as it is on a chevy motor RIGHT? lol
I love Blue
The header are from Flowtech. part number "91830FLT". bought them at Lordco.
Can't wait to hear the ROAR coming out of the Exhaust.
As for my close friend there? i will PM you. i definitely need some parts
Chevy owned:
98 GMC Safari AWD
Post by doyoulikeithere » Sat May 19, 2012 5:39 pm
Thats not FORD blue.... :axe:
It looks like the GM blue that they used to paint the GM marine engines with.
My friend had GM blue on his original GM250L6 OMC boat engine.
Oh, and I also have a GM Blue engine. The rattle can even said "GM Blue" :rolleyes:
I was thinkin the same ford thing too, but when I saw that on the can, I was sold... Lol.
Post by astrozam » Sat May 19, 2012 8:46 pm
Looks good so far :cheers:
lockdoc
Post by lockdoc » Sun May 20, 2012 2:56 am
Nice! I am also a fan of the Chevy blue. They used blue on the V8's in the 80's and also on the inline 6 cylinders. I used valve covers from a Chevy full size van which allowed me to use the stock oil fill tube.
Current:
01 AWD - Stock
98 AWD - Stock
Past:
94 RWD - 350 V8 - sons van
92 RWD - stock - sons van
93 RWD Shorty - project
89 RWD Shorty - parts van
AquaAngel
Post by AquaAngel » Sun May 20, 2012 5:34 am
Lots got done today new EGR valve was installed, timing chain finally got in and installed, more chrome parts got installed, new sensors and valves got put on, Harmonic balancer finally met the engine
Part of my work done today
All my new Valves and sensors
Rear Main seal installed
See the motor? see the van behind it? that motor is going that van. YAY
my cleaned up harmonic Balancer
more pics of the valve and sensors
Thanks to Snap on, i tried Lordco, napa, hartman in Courtney and other parts dudes around and not Even GM dealer would sell me that. Snap on had it and took it from them.
New Harmonic balancer has finally met his new motor
THANK YOU SNAP ON!!!!
Chevy owned:
98 GMC Safari AWD
Post by Smiliesafari » Sun May 20, 2012 1:21 pm
Those valve covers sure cleaned up nicely. Everything looks good so far. Not that you haven't already thought about it... but.... you may want to use the dipstick from the 4.3. The one that is on the engine now will make checking the oil a pain. :supz:
AquaAngel
Post by AquaAngel » Mon May 21, 2012 5:06 am
the oil dipstick was replaced from a Chevy Suburban 94, the latest pic has that one replaced, the straight one is now gone. :-$ :yellin:
Chevy owned:
98 GMC Safari AWD
AquaAngel
Post by AquaAngel » Mon May 21, 2012 5:11 am
this is my new dipstick, well sort of new off a Suburban 94 K1500 model
Also my Chrome oil pan is coming Wednesday, so for the time being, i will do the timing while the pan is off so i can find my TDC and do the proper timing work on it.
So i can fool around with the oil pump shaft if my dist shaft doesn't get in there properly. :whistle:
Chevy owned:
98 GMC Safari AWD
AquaAngel
Post by AquaAngel » Fri May 25, 2012 3:30 am
my Chrome oil pan finally came in
Sweet look at it
Looking good
Chevy owned:
98 GMC Safari AWD
HotrodDaddy43
Post by HotrodDaddy43 » Fri May 25, 2012 4:27 am
Funny those must be the go to lights I have the same ones in the same place
AquaAngel
Post by AquaAngel » Sat Jun 16, 2012 3:07 pm
Also picked up a Close to "NEW" tranny for the van. picked up at power House in Cumberland for 450 bux.
Tranny has about 2,500 km on it. beats from having my other one Rebuild.
Will soon start to take the van apart and do the swap. Dying to hear the motor going.
:muhaha:
Chevy owned:
98 GMC Safari AWD
