The V8 Club-a list of members
AstrSafariFamily
Re: The V8 Club-a list of members
Post by AstrSafariFamily »
I have a 86 Safari with a 88 tbi motor, 700r4 trans with shift kit and 3:08 posi rear end. I am currently working on another project a 97 Safari AWD and looking to replace the dead 4.3 vortec with a 5.7 vortec
kc5gxl
Post by kc5gxl »
Howdy all;
I sat my 305, bored 60 over, in my 91 shorty last spring, but my job at the school got cut, so had to haul it home for the summer. However, I am now teaching about 200 miles north of where I used to be, and will be hauling the Safari up to Tyler Texas in a few short weeks, to continue the install. The engine and trans are bolted in, but nothing is hooked up to them yet.
Hopefully by the spring, the heart will start to beat again in the ol' Saf. :supz:
Drive safely,
Dan Harriman
Tyler Texas, formerly from Orange, Texas
If at first you don't succeed, maybe you shouldn't try sky diving!
Jinmajay
Post by Jinmajay »
Can I add mine to the list now or does it have to run first? Can you tell I'm excited? :muhaha:
The Tran man http://jayjensen.shutterfly.com/action/
1994 AWD GMC Safari, V8 truck van project
1998 2WD Astro
1999 AWD Astro
badassastro
Post by badassastro »
I have had a V8 Astro for 12 years now. It is an 85 Astro with a 85 Corvette Tuned Port Fuel Injection motor.
pictures: http://www.cardomain.com/ride/2392473/1 ... olet-astro
I am working on a full show Astro. I dont have the funds I had when I started, but will be done someday.
85 pro street Astro, parted & scrapped
98 pro street Astro, 33x22 rear tires, all aluminum 335 hp LS1 motor
PRO STREET 4 LIFE
wdmickjr
Post by wdmickjr »
I still have my 87 Astro CS, with 94 LT1, but.. It is in rebuild right now. I installed a HV oil pump and was going down a hill and decided to put it in 2nd and listen to the pipes...too much for the oil pump drive, and locked up engine before I got home.
Hopefully the main journals are ok and the crank can make .010 or .020 on both; journals and mains. Even tho turned the stock crank is better that some aftermarket new cranks. I will bore it out to .030 and have new rods and pistons. Found a guy who will port iron heads for cheap and use the iron heads, 1.6" rr and pacesetter long tube race headers. Probably also go with the MSD opti KIT.
94 Roadmaster LT1 (w/ Soloman Power Tune) powered 87 Astro CS
That stinks! :yikes: Sounds like it will be stronger and better for it one the rebuild is done.
