Repair a plastic bumper.
This show what kind of plastic it is. This is SAAB, PP+EPDM-M10
In this case, there are three components in the plastic, that means you have to glue.
If it´s 2 components in the plastic, for example: PP+EPDM , you can weld it.
The M10 means there are 10% of some filling material, and that can´t be melted. So no welding.
Here is the damage, a hole.
First heat treatment with a IR heater, to make the plastic soft
Here I roll the back of the bumper to get the dent out.
Then I sand the back with P240 sanding paper.
Clean the area with 3M Surface cleaner, it´s a alcohol-based cleaner.
Spray on a Plastic Primer.And let dry 5 minutes or more.
In order to strengthen the glue on the backside I use a glass fiber net.
Add glue. I use Terokal-9225 from Teroson alot, works to 90% of the plastics that are in cars.
Let dry a couple of hours.
Now the outside. Sand with P240 and grind a ditch in the crack, then clean the same way as before.
Plastic Primer.
Glue. You can choose to just glue the crack, and then shape it with bondo.
I choose glue for both the crack and to chape
I let it dry till the next day to be sure it harden enugh to chape it with a rasp.
And sand it with P240.
Clean and spray on plastic adhesion promoter and 3 coats (it´s about 150-200μ) of MaxMeyer Filler 0310.
After I hour in 70ºc, it´s ready to prepare for paint.
After sanded with P600.
Painted.
Repair plastic bumper
Re: Repair plastic bumper
Excellent work!,You kick ass
Want to paint my 1949 Massey Harris Pony?
90 Astro Cargo V-8
& a bunch of tractors
Awesome repair! Looks better than new.
Super job on the repair! Nice shop too. Thanks for the pics. I'll be working on my Wife's damaged rear bumper (Isuzu) this summer.
Past vans: 1990 2WD SLE Safari, 1990 AWD SLE Safari, and 2000 AWD Safari SLE. Current, 2004 Astro AWD LS.
- I am merely driving my van
