The first diesel Astro conversion??.
Moderator: mdmead
GEJ
Post by GEJ » Thu Sep 25, 2008 2:12 am
There are a number of new members now.I thought I would bring up the age old question again.Who here is going to swap the first diesel into a Astro??.I can tell you all it won't be me,but it is a subject of common interest. :-k
Call me Gary
1985 Astro-"Ole Yellar"
1994 LT Astro
1981 Winnebago-"Baby"
12'dual axle enclosed trailer
The vendor trailer
Cobra
Re: The first diesel Astro conversion??.
Post by Cobra » Thu Sep 25, 2008 1:14 pm
diesel sounds intresting especially because i do long runs and intend to be towing but i know it won't be me for some reason the idea of working on a diesel frightens me (not like i really know anything about ICE's either tho), not the mention the cost and availability of parts not for me
astro355
Post by astro355 » Thu Sep 25, 2008 9:35 pm
GEJ wrote:There are a number of new members now.I thought I would bring up the age old question again.Who here is going to swap the first diesel into a Astro??.I can tell you all it won't be me,but it is a subject of common interest. :-k
Well, gary. I was going to say whats the point until my wife reminded me about that V8 in my van. ](*,)
Not a member of the good ole boys.
T.Low
Post by T.Low » Thu Sep 25, 2008 9:43 pm
Someone's always reminding ya about the V8's. If its not the wife, then its the family dog. Sheesh.
http://www.youtube.com/watch?v=xNvdnZ04Tjc
AstroLander Build Slideshow
kings-x59
Post by kings-x59 » Fri Sep 26, 2008 2:38 am
would the mileage be high enough to offset the high cost of diesel these days? down here, diesel is still more expensive than premium gas.
name's Steve
COMP
Post by COMP » Fri Sep 26, 2008 5:45 am
you could run bio
astro355
Post by astro355 » Fri Sep 26, 2008 1:40 pm
:withstupid:
Rockwerx
Post by Rockwerx » Fri Sep 26, 2008 4:26 pm
kings-x59 wrote:would the mileage be high enough to offset the high cost of diesel these days? down here, diesel is still more expensive than premium gas.
This would depend on which engine you used of course. There are many good reasons to run a diesel. Some of them you can tweak for more performance which usually makes them perform better on fuel...kind of backwards to a gas engine. The more you tune up a diesel, the better the fuel economy you get in just about every application...weather you are towing, racing or just cruising. Due to the nature of the fuel (more of an oil than a solvent), diesels last many times longer than gas engines.
I have been running diesels for almost 30 years and they just keep building them better and better. Some of the newer ones with electronic controls are using multiple event fuel injections per power cycle to gain more power and torque. These newer diesels run alot quieter and are WAY more fuel efficient than the last generation of diesels.
At one point I had measured everything to install a GM 6.5 turbo diesel into our favorite vans. It would fit with some major mods to the heating/AC system on the firewall. The next challenge would be to install a large enough rad and intercooler. This swap would give a guy lots to fabricate, but in the end you would have a pretty hot towing machine.
If you are going just for fuel economy then I would find a smaller 4 cyclinder or even a small inline 6 cylinder turbo diesel (Izuzu, Cummins, VW). What ever diesel engine one uses I would make sure that it is turbo charged. You will not realize the fuel potential in power/torque/fuel economy without a trubo on a diesel engine.
1988 V8 Safari Panel
1985 V8 Astro Panel
1990 V8 Astro LT AWD Lifted
1988 V6 Astro Panel
1990 V6 Astro Panel
1991 V6 Safari SLT AWD bad engine knock
19?? V6 Safari SLT for parts
ihatemybike
Post by ihatemybike » Fri Sep 26, 2008 4:59 pm
I've thinking of the diesel swap for a while. I think the easiest swap fit wise at the moment would be a diesel engine from either a wrecked Jeep Liberty 2.8L CRD or Jeep Grand Cherokee 3.0 CRD. Ideally GM would hurry up and get their new 4.5L Duramax to market and then swap that in.
COMP
Post by COMP » Fri Sep 26, 2008 5:05 pm
a GM 6.5 would be a beast
GEJ
Post by GEJ » Fri Sep 26, 2008 7:50 pm
I think Mr_Roboto who has spent tons of time looking at different turbo set-ups has said a V8 diesel would take a down stream turbo to fit it into a Astro.So as the saying goes-"build it and they will come".That is design a kit and they will buy.
Call me Gary
1994 LT Astro
The vendor trailer
potskie
Post by potskie » Sat Sep 27, 2008 1:33 am
Was it Badassbee that was working on the 6.2 install? I wonder how that one is coming along anyways.
At work right now I'm driving a turbo 6.0 Powerstroke. As much as I am not a fan of FORD I have to admit this freaking truck just hauls ass. I wonder if a Powerstroke is possible.
Best swap tho would defiantly have to be a 4BT. I've seen a few popping up around here for sale and everytime I see one it takes an amazing amount of will power to not just go run and buy it.
Image 98 Safari RWD. Stock.
TheHarv
Post by TheHarv » Fri Oct 17, 2008 4:57 pm
I believe there was a thread on the Overland Van site. Possibly the owner before Dan. I will have to see if it it still there.
Harv
http://www.overlandvans.com/0104_diesel.html
GEJ
Post by GEJ » Fri Oct 17, 2008 9:14 pm
TheHarv wrote:I believe there was a thread on the Overland Van site. Possibly the owner before Dan. I will have to see if it it still there.
Harv
Wow-I don't remember seeing that ref before.All along I thought the cummins was too long.Very interesting for sure.
Call me Gary
1994 LT Astro
The vendor trailer
TheHarv
Post by TheHarv » Sat Oct 18, 2008 12:36 am
I have been watching for one of those motors but having been unemployed for a while makes it not even reasonable to consider right now. #-o
