ran into a snag-help please!
Moderator: mdmead
markmitchinnh
Post by markmitchinnh » Sat Jul 07, 2012 3:34 pm
Ok I am doing the 4.3 to 5.7 swap and on the pass side cylinder head there is a sensor on the V6 and on the V8 there is a plugged hole (threaded) I took the plug out and tried the sensor but its to small. Anyone know what this sensor is and is the V8 sensor bigger? Thanks to anyone with info on this. Mark
markmitchinnh
Re: ran into a snag-help please!
Post by markmitchinnh » Sat Jul 07, 2012 4:42 pm
I figured it out , its a temp switch for the temp gauge.
Mr_Roboto
Post by Mr_Roboto » Sun Jul 08, 2012 3:52 am
buy an adapter for the pipe, should be easy to source. If I remember correctly, I had to buy one when I did the swap. If you have the sensor off the 350, it will be compatible if it plugs into your harness which it should (they pretty much all use a spade terminal)
markmitchinnh
Post by markmitchinnh » Sun Jul 08, 2012 10:53 pm
the sensor is on the other side on the 350 so I just had to put a threaded plug into the hole on the 350 head. Thanks for your assistance Mr_ Roboto
markmitchinnh
Post by markmitchinnh » Sun Jul 22, 2012 9:37 pm
Anyone know which top radiator hoses will work? the V6 hose does not fit.
Kidhauler
Post by Kidhauler » Mon Jul 23, 2012 12:20 am
V6 hose should work if you cut a couple inches off I beleive.
1999 Safari Touring edition.
teal green
300 000 kms
markmitchinnh
Post by markmitchinnh » Mon Jul 23, 2012 2:28 am
it does not fit on the water neck on top of intake manifold, The V8 intake water neck is bigger around then the V6 component.
