Dutch door weatherstripping
Moderator: trybe13
sfeaver
Post by sfeaver » Thu Dec 04, 2008 10:56 pm
For those who are getting tired of wet carpet due to the back doors leaking, I found a place that sells the seals and are OEM GM stuff. It is part numbers 15046999 - $82.50 for the left door, 15047000 -119.91 for the right. Since this last year I have had the seats and carpet out three times to dry, it is worth 200$ plus shipping to me!
Thats a lot cheaper then the dealership wanted around here even with a big discount!
The place is called Monster Parts Online, their website is: http://www.trademotion.com/partlocator/ ... eid=214632
Scott
crash
Re: Dutch door weatherstripping
Post by crash » Fri Dec 05, 2008 1:22 pm
good to know Scott.. what really gets me is what changed from 93/94 on the dutch doors to my 99 for example??
both the 93 and 94 have no leaks at all around the dutch doors. with my 99 I have an annual summer carpet removal and 3 days laying of a bbq and lawn chairs dry out period. this past summer the underpadding started falling off the carpet... I dried it out.. rolled it up and put it in my basement and put some indoor outdoor black stuff that I got at walmart cheap (6'x9') .. I think I got like 3 of those and cut them to roughly cover most of the area that gets traffic from behind the front seats to the back doors.
best I can track my leak down to is right across the very bottom where theres no lip. the water runs down the edges (sides) of the dutch doors and along the weather stripping on the bottom, pools in the corners and trickles in. problem being that the weather stripping is designed to meet the plastic trim piece that runs across the back at the edge of the carpet..... the water runs under that so weather stripping isn't the issue on mine
Rob Image
current rides:
04 Mazda 6 V6 5spd
vans owned: Image
99 Astro LS Sept 08 ASV VOM
94 Astro LT
93 Astro LT
96 Astro LT AWD * parts van*
Cobra
Post by Cobra » Fri Dec 05, 2008 1:38 pm
hmmm that's definetly something i need, the wet carpet is a little old....
mine leaks in the same place crash and it looks like it's the weather stripping on the side of the door is were the leak is runs down from the top along the side seeps in and runs the rest of the wawy down on the inside of the weather stripping then pools at the bottom
astronut74
Post by astronut74 » Fri Dec 05, 2008 1:47 pm
Holy cow! That is alot cheaper than the stealership! I gonna have to get me some of that!
Steve O
94 2WD Astro EXT
179,000 miles and counting
Going from an 8 seater to a 4 seater
SoCalli V8
Post by SoCalli V8 » Sat Dec 06, 2008 5:56 am
Great info, even thou it don`t rain to much here in SoCal, but rubber weather stripping gets fried from the sun overhere. Then it cracks..... and looks fugly, and then when it finally rains.... > It Leaks...!
blacknome
Post by blacknome » Tue Apr 21, 2009 6:08 pm
There must be some kind of fix for this.
I have been trying to hunt down a funky odour in the van since last fall and I think I found it !
I was cleaning out the van on the weekend and noticed water in the little wells in the floor where the seats for the very back clip in. Funny thing is that the carpet in the van is dry but when I pulled up a small section by the rear door the underpad is soaked. So much so that when I tried to pull the carpet out of the van I could not lift it ( girly man I know :) ). I ended up taking the van to work and pulling out the carpet with a length of rope and the forklift. Carpet and underpad are up on a stack of skids and there must be a good 1/2 gallon of water on the floor that has run out since yesterday.
I was thinking about removing and leaving off the the piece of trim which transitions from the van floor to the carpet and replacing it with a piece of aluminum bar screwed and siliconed to the floor appx 2" away from the rear door so the water will at least pool by the back door and not soak the carpet.
WVKayaker
Post by WVKayaker » Wed Apr 22, 2009 3:26 am
That's a pretty good idea...I am dealing with this crap again and again....
Helwig Rear Anti-Sway Bar
BFG AT KO 235/75/15
Cragar Nomad I Wheels
blacknome
Post by blacknome » Wed Apr 22, 2009 2:16 pm
I hope it works too. I will try once the carpet dries out. It's still dripping water out of the underpad and there was a good cup or two of water on the floor this morning ( and this has been sitting on a stack of skids in the warehouse since Sunday !
I gotta figure out how to dry it faster before it starts getting mouldy. It's about 15 deg C in the warehouse and the forcast is for showers and clouds for the next 2 days so I can't put it outside.
WVKayaker
Post by WVKayaker » Sat Apr 25, 2009 2:19 am
squeegee that water out...I used the blade of a hand cart
BFG AT KO 235/75/15
Rileysowner
Post by Rileysowner » Mon May 04, 2009 2:24 pm
Same situation here. Soaked underpad. I noticed it when I was crawling into the back of the van and where my knee was the water would start to come through. I have seriously considered taking the carpet out, cutting off the section just behind the back seat and getting someone to seam up the end of that. Then paint from that point back with some sort of bed liner coating.
Anyone replaced the weatherstripping yet? How did it go and did it solve the problem? It seems the weatherstripping on mine is dry and shiny which would explain its lack of seal.
blacknome
Post by blacknome » Tue May 05, 2009 2:48 am
well I have left the carpet out for the last couple of weeks to see where it's coming in. I found that in my case the plastic strip accross the back on the floor which transitions the metal floor up to the level of the carpet sits on a bead of butyl tape. The water seems to run down the back of the doors and in thru an 1/8th inch gap on either side and back into the van at the jack storage point and under the rear A\C which could explain why my carpet was more wet in those areas.
I have yet to break out the caulking to address this issue, and I will snap some pics when I do.
Post by LiftedAWDAstro » Tue May 05, 2009 3:45 am
Blacknome...gonna need to replaced the door seals. That is why the water is getting inside the door to the area where the plastic covers the body seam. I had the same problem once in the SPB. No amount of caulking, silicone or tape would fix the leak. New seals and it still doesn't leak (that I know of).
blacknome
Post by blacknome » Sat May 09, 2009 4:21 am
hmm not liking the sound of that. I have kinda gotten used to driving around with no rear carpet over the last few weeks. It was a little loud at first and worse when raining but I am seriously thinking of putting down some truck bed liner and some rubber backed mats ( like you have at the front door of an office to wipe your boots off on ).
My truck is used 90% for work and deliveries anyways.
blacknome
Post by blacknome » Fri Jul 10, 2009 2:24 pm
OK first off, sorry but I have hi-jacked the post...... but the problem is fixed
After driving the van for 3+ months now with no carpet, I figured out that the water is leaking in thru here.
^^^ It;s kinda hard to describe but the water runs down the hatch and where the hatch meets the dutch doors some of the water transitions and runs along the weatherstrip to the bottom corners. As you can see in the pic above there is a gap between the trim and the lip in the steel ( covered in black plastic ). This gap should have been covered by the 1/2" wide strip of Butyl Tape which is running both inside the van from side to side and/or by a parallel strip of Foam Tape which is on the underside of the plastic trim. I ended up with a good 1/8"-1/4" gap in-between the 2 strips in my van [-X . Doesn't sound like much but this would let a majority of all that water running down the inside of the back door,around the foam and butyl tape and soak the underpad of my carpet.
So, originally I just wanted to make a "dam" of silicone to keep the water out and I was just going to live with the problem. I have found though that with that bead of silicone in there the water has been staying out and it has been working really good. I got confident and went ahead and put the carpet back in last week ( without the rear trim peice just so I can keep and eye on things ). I have tested it with the hose and even took the van thru the carwash and that bead of silicone is keeping the water on the outside portion of the van and not letting the water back in the vehicle and soaking the carpet again.
See how the water puddles on the outside now ?
So really I just wanted to update my progress in hopes that someone will stumble across this post and have a fix for thier van and help them out ( which is what this site is all about !! ) Thank you AstroSafariVans for all of your help towards me over the years.
And in closing I feel like a dummy because I could have fixed this in 5 mins by using a small strip of Butyl on either side to fill the gap left by the installers to begin with. Instead I have multiple hours into removing, cleaning and re-installing the carpet and trim and everything else. But one nice thing is that my van doesn't smell funky anymore and the carpets will stay dry !!! \:D/
Rileysowner
Post by Rileysowner » Fri Jul 10, 2009 3:52 pm
So when you re-install the trim this still works? Hummmm. I think I will have to take this apart and see what I can see.
