side sliding door needs some help
pengyou
Post by pengyou »
To open the door I pull the latch and then, with my left index finger I have to reach other to the left end of the door and pull it out a little to get the door slide. Which part needs to be adjusted/replaced/repaired?
New owner of a 1996 Astro named "Plain Jane" - stock right now - with 200,000 miles on it and running like a champ
CaptSquid
Re: side sliding door needs some help
Post by CaptSquid »
Spray some spray grease in the latch mechanism at the rear of the door. It's dry -- BONE DRY.
Post by Smiliesafari »
Try a little WD40 to loosen things up. The WD40 will wash out some of the crud that is making it stick. Then spray it with some grease. That rear latch is spring loaded. The the rear of the slider should pop open when you pull on the handle. \:D/
stomp13
Post by stomp13 »
I had the same issue, I sprayed the crap out of latch mechanism with PB blaster and went back a couple days later and greased it.
99 Astro LS AWD. 200k. Overlands 2inch lift. No name 29inch LT tires.
Rebel
Post by Rebel »
I had that prob also,,I filled by slider,,no more issues there. :yawinkle:
VIDEO
SoCalli V8
Retired
Retired
Post by SoCalli V8 »
I modified my sliding door into a Gulwing door.... I have had no further issues....
Rebel
Post by Rebel »
:yawinkle:
VIDEO
CaptSquid
Post by CaptSquid »
You two is talkin' 'bout REAL money. The newb is talkin' CHEAP.
pengyou
Post by pengyou »
Yes cheap....cheap...cheap, cheap, cheap, cheap...just call me chicken little :)
I bought some liquid wrench and doused the latch...it is working much better now.
I will douse it again tomorrow...and then put some grease on it.
I have noticed that when I close the sliding door I cannot get it started by pulling the latch from the outside but must reach inside and pull it. Is that the way it is designed?
Been thanked: 2 times
Post by astrozam »
pengyou wrote: I have noticed that when I close the sliding door I cannot get it started by pulling the latch from the outside but must reach inside and pull it. Is that the way it is designed?
Are you parking on a hill when you have noticed this?
No, it's not normal. The lower latch is activated by a cable. I think the cable stretches a little over time causing that problem. My '96 Safari did the same thing. I cured the problem buy adding a small spacer (flat washer) between the swaged end of the cable and the latch. \:D/
Rileysowner
Post by Rileysowner »
Smiliesafari wrote:No, it's not normal. The lower latch is activated by a cable. I think the cable stretches a little over time causing that problem. My '96 Safari did the same thing. I cured the problem buy adding a small spacer (flat washer) between the swaged end of the cable and the latch. \:D/
Could you snap a pic of this fix?
Wiley
Post by Wiley »
I added pics of the interior sliding door mechanisms here in a similar thread:
Sliding door frozen shut will not open
