side sliding door needs some help
Moderator: trybe13
pengyou
Post by pengyou » Fri Nov 14, 2008 6:56 am
To open the door I pull the latch and then, with my left index finger I have to reach other to the left end of the door and pull it out a little to get the door slide. Which part needs to be adjusted/replaced/repaired?
New owner of a 1996 Astro named "Plain Jane" - stock right now - with 200,000 miles on it and running like a champ
CaptSquid
Re: side sliding door needs some help
Post by CaptSquid » Fri Nov 14, 2008 8:05 am
Spray some spray grease in the latch mechanism at the rear of the door. It's dry -- BONE DRY.
Mike, Billings, MT, 'MERICA!
98 AWD Stro LS
93 Suburban Silverado 4x4
Post by Smiliesafari » Fri Nov 14, 2008 1:49 pm
Try a little WD40 to loosen things up. The WD40 will wash out some of the crud that is making it stick. Then spray it with some grease. That rear latch is spring loaded. The the rear of the slider should pop open when you pull on the handle. \:D/
stomp13
Post by stomp13 » Fri Nov 14, 2008 3:09 pm
I had the same issue, I sprayed the crap out of latch mechanism with PB blaster and went back a couple days later and greased it.
99 Astro LS AWD. 200k. Overlands 2inch lift. No name 29inch LT tires.
Rebel
Location: Evergreen, Al. 96 mile marker, where life is slow and there are no rules.
Post by Rebel » Sat Nov 15, 2008 10:30 pm
I had that prob also,,I filled by slider,,no more issues there. :yawinkle:
89 Astro, 350 V-8, Shaved doors, Filled Slider, Corvette IRS, 94 Mustang GT Rack & Pinion(Thanks to Skip),
VIDEO
If you drive illegally, they take your driver's license. If you're here illegally, they want to give you one :)
If guns kill people, do pencils misspell words
SoCalli V8
Post by SoCalli V8 » Sun Nov 16, 2008 3:01 am
I modified my sliding door into a Gulwing door.... I have had no further issues....
`86 V8 Lowered Cargo, extensively modified, shaved bald, wearing the shortest, sluttyest white primer dress....
A British Wanker living in So KarlyFornia.
My Astro tows my toys to Glamis sand dunes http://www.youtube.com/watch?v=jp2pqjQtpso
First ever canal jump at Glamis http://www.youtube.com/watch?v=oXZjM84x_Xc
Rebel
Post by Rebel » Sun Nov 16, 2008 3:13 am
:yawinkle:
VIDEO
CaptSquid
Post by CaptSquid » Sun Nov 16, 2008 4:29 am
You two is talkin' 'bout REAL money. The newb is talkin' CHEAP.
98 AWD Stro LS
pengyou
Post by pengyou » Sun Nov 16, 2008 7:09 am
Yes cheap....cheap...cheap, cheap, cheap, cheap...just call me chicken little :)
I bought some liquid wrench and doused the latch...it is working much better now.
I will douse it again tomorrow...and then put some grease on it.
I have noticed that when I close the sliding door I cannot get it started by pulling the latch from the outside but must reach inside and pull it. Is that the way it is designed?
astrozam
Post by astrozam » Sun Nov 16, 2008 5:17 pm
pengyou wrote: I have noticed that when I close the sliding door I cannot get it started by pulling the latch from the outside but must reach inside and pull it. Is that the way it is designed?
Are you parking on a hill when you have noticed this?
Post by Smiliesafari » Sun Nov 16, 2008 5:30 pm
No, it's not normal. The lower latch is activated by a cable. I think the cable stretches a little over time causing that problem. My '96 Safari did the same thing. I cured the problem buy adding a small spacer (flat washer) between the swaged end of the cable and the latch. \:D/
Rileysowner
Post by Rileysowner » Mon Nov 17, 2008 12:19 am
Smiliesafari wrote:No, it's not normal. The lower latch is activated by a cable. I think the cable stretches a little over time causing that problem. My '96 Safari did the same thing. I cured the problem buy adding a small spacer (flat washer) between the swaged end of the cable and the latch. \:D/
Could you snap a pic of this fix?
Wiley
Post by Wiley » Tue Apr 02, 2013 7:27 pm
I added pics of the interior sliding door mechanisms here in a similar thread:
Sliding door frozen shut will not open
