Safari Grill
blk lt awd
Re: Safari Grill
Post by blk lt awd »
my apoligies...i was describing the difference between a sealed beam and composite........however both sealed beams should be the same except for the lower mount........let me know......thanks.
1995 Black LT AWD
2000 Ninja ZX-6R
2003 Mazdaspeed Protege (spicy)
1961 Impala...gone but not forgotten.
http://www.propertystation.ca/
meetthespeakers
Re: Safari Grill
Post by meetthespeakers »
Bump..Updated at top
1993 Astro, 1973 Austin Mini Clubman Estate, 1980 Trabant, 1961 Morris Minor
dme3o
Re: Safari Grill
Post by dme3o »
Hey guys, I'm looking to change the stock SEALED BEAM grill on my '99 Astro cargo van into a GMC Safari Grill. So, just to make sure I did not misread:
The GMC SAFARI GRILL should BOLT ON to an ASTRO? Is that correct?
skippy wrote:Yes it will bolt in place of the astro grill , when lockdoc put the newer nose on his now my 92 astro he first put a 95 astro nose on it & then switched to the better looking safari grill & lights .
DME3O
1999 CHEVY ASTRO CARGO (in coversion process)
dme3o
Re: Safari Grill
Post by dme3o »
Hey guys, any chance you can re-post the pics? I'd like to see what I'll be up against before I take the plunge and splurge on this.
Thanks!
O:)
DME3O
infinite.chris
Re: Safari Grill
Post by infinite.chris »
dme3o wrote:Hey guys, any chance you can re-post the pics? I'd like to see what I'll be up against before I take the plunge and splurge on this.
Thanks!
O:)
I know the grill itself doesn't have more than maybe half a dozen screws on it. Can't speak for a passenger van, but I /think/ it's the same. I could prolly pull mine in 5 minutes if it wasn't so dang'ed cold out ;P
[SCRUFFY 95 RWD Astro Cargo :: 227k ]
justice
Re: Safari Grill
Post by justice »
its funny that this thread is back up..i had forgotten about it. Back when it was first posted I was only driving pre 95 Stros with the old front end. But this is the EXACT swap I want to do on my 2004 Astro. Safari grill with the billet insert!
TO answer a question. If you are going to swap a sealed beam Astro grill for a sealed beam Safari grill, it should be a direct swap. If you want to switch to the composite headlights you will have to alter the headlight wiring and get the Safari trim panels as well i believe.
I have a ban hammer and I ain't fraid to use it!
Current - 2004 Astro Cargo
Former
95 Safari (money pit - sold)
93 Astro Cargo (totaled)
85 Astro - (Bought for parts and scrapped)
92 Astro Conversion (sold)
87 Safari Shorty (sold)
dme3o
Re: Safari Grill
Post by dme3o »
Thanks sir! Yeah...I would like to swap my SEALED BEAM Astro Grille for the SAFARI Composite grille.
Anyone out there done this that can post some pics?
DME3O
justice
Re: Safari Grill
Post by justice »
dme3o wrote:Thanks sir! Yeah...I would like to swap my SEALED BEAM Astro Grille for the SAFARI Composite grille.
I believe Stan (HpByStan) has done this swap..i think there is a post here about it.
Former
dme3o
Re: Safari Grill
Post by dme3o »
Thanks justice!
Will do a search! Much obliged!
DME3O
blk lt awd
Re: Safari Grill
This what i did.
1995 Black LT AWD
2000 Ninja ZX-6R
