do you guys know if tires 31/10.5/r15 will fit on stock susp
HAVE A TIRE QUESTION? LIKE YOUR TIRES AND WANT TO LET EVERYONE KNOW? NEED TO KNOW IF THEY WILL FIT? POST IT HERE.
spl.tattoo
Post by spl.tattoo »
Hi!
I have a 1997 safari 2wd.
I have a deal on 31/10.5/r15 on z28 mags, I know this is not my bolt pattern but I'm gonna buy adapter for that.
I wanna know if they will fit on my van with a stock suspenssion...? You have to know that my adapter have 3/4" like a spacer...
Thanks and I hope have good news!
1997 GMC SAFARI 4.3L VORTEC RWD
-wheels spacers 1.5"
-electric exhaust cut-out 3"
-clarion mp3 tv dvd unit
zombie{[six]}
Re: do you guys know if tires 31/10.5/r15 will fit on stock susp
Post by zombie{[six]} »
they will fit on the rear, but the sliding door will hit the tire. As for the front. Nope. Biggest stock is 235/75-R15, which even then you have to do some hammering of the wheel well.
To fit 31" tires up front you would need at least 3" of lift
crate 350 bored .60 over, 700R4, lifted...yada yada yada. Who cares what i have, ITS FAST AND I LOVE DRIVING IT!!!
spl.tattoo
ok but what is the biggest size i can put on the back,( i want my sliding door open lol) the wheel are camaro z28 1985 15"
and sorry for the error, the adapteur is 1"1/4, not 3/4"!!
zombie{[six]}
you can run 31" tires. the door just rubs on the tire. no biggie.
LaGrasta
Has thanked: 2 times
Post by LaGrasta »
In terms of BFGs, the 30" is only 9" wide versus 12" on with the 31".
1998 Astro, 246,000 miles
Post by mdmead »
Rim width... and your spacers... are going to be the problem with the sliding door. I think if you kept a rim size of 7", without the additional 1.5" spacer, you would be fine. I know some folks have run 8" rims and even wider, so they can chime in.
spl.tattoo
thanks for reply...but..I'm still not have my anwser... somebody tell me they don't fit,, others says they will...
No-one have already try to put 31" on stock suspenssion? if yes, do you have 1"1/4 betwer your tire and the sliding door?
because I have a great deal for 31" on camaro wheels... please I need a confirmation because i cannot try because he is far away to my home
LaGrasta
Post by LaGrasta »
without modification to numerous items, they will NOT fit.
zombie{[six]}
I ran 31" tires and they rubbed on the door. I already told you this homeboy.
spl.tattoo
ok
LaGrasta
What do you mean by many modification? what I should have to do? You talk about the front? because if they dont fit in the front i will put original size (215/75/r15), but I really want to have 31¨ in the back (look nice but i'm not sure if it safety to put 31¨ just in the back)...
zombie{[six]}
I know you have 31¨ on your van but do you have 1 1/4 spacers on it? if not and you already rubs the sliding door, I know my door will not open. but If you have spacers and the door open (even if they rubs the slidding door) it will be ok to me and i will be happy!! lol.
thanks
As everyone else has said...NO the 31x10.5R15's will not fit on a stock suspension van unless you want to do a LOT of trimming and cutting up front. Depending on the backspacing or offset the wheels have, you may be able to get away with the spacers and still be able to open the sliding door.
There is a lot of reading on fitting wheel/tire combos in this section, 4 pages worth...time to do a lot of research.
97CargoCrawler
Post by 97CargoCrawler »
NO they won't fit, and even if you somehow made them fit they would probably look pretty stupid.
Buy the wheels, and then buy a lift kit for your van. Ahhhh, problem solved!
=D>
Spacers will most likely make the slider rub the tire, or hit the tire allowing the door to open only halfway, like mine. I have 1.5" spacers.
1997 SAFARI 2WD CARGO
"I do not think there is any thrill that can go through the human heart like that felt by the inventor as he sees some creation of the brain unfolding to success... Such emotions make a man forget food, sleep, friends, love, everything." Nikola Tesla
spl.tattoo
thanks to any comment! but i dont want to lift my van..i think i will put some 215/50/r15 on the camaro wheel.
thanks you everybody
BLAZER
Post by BLAZER »
I'm thinking you may not have to worry about rear tire rub on the rear door. The 3rd gen camaro wheels have a little more backspacing than the Astro wheels depending on the wheels. Your spacer/adapters may actually move wheel into about the proper stock position. You need to measure the backspcing on the camaro wheels and see what you can get away with. I ran 31's on stock fullsize Chevy truck rally wheels and had about 1/2-1" of clearance on the slider. I had a 95 2WD and had 5" of lift and still had to trim the front bumper and front fender a bit for rubbing. My van came with 235/70/15's and doubt I could go any larger without rubbing.
