31s and stock alum wheels...
HAVE A TIRE QUESTION? LIKE YOUR TIRES AND WANT TO LET EVERYONE KNOW? NEED TO KNOW IF THEY WILL FIT? POST IT HERE.
scarecrow
Post by scarecrow »
i did a search and came up with nothing..i have a 95 AWD i just ordered the 4 in lift. i plan on running 31s. my question is can i run a 31x10.5x15 tire on my stock alum wheels???
SOLD and missing my 1995 Astro AWD 5 1/2 lift and 31 inch tires...
ihatemybike
Re: 31s and stock alum wheels...
Post by ihatemybike »
Check this.
Wheel And Tire Information
BF Goodrich says the 31" All Terrain TA KO need a 7-9" wide rim. According to the post above the stock rims are 6 1/2" wide. Might work, but probably not recommended.
Aaron
Prev Astros:99,97,00,94,87,86
scarecrow
Post by scarecrow »
a 10.5 wide tire is ok to run on the 6.5 wheel my question is will it hit anything on the van..
ihatemybike
From what I've read, generally 4" lifts and 31" tires require some trimming of the front fender wells. Rubbing occurs near the outer limits of the steering range.
Aaron
cd0156
Post by cd0156 »
I have BFG A/T KO 31/10.5/15 tires on mine with a 4" Overland lift.. I had to do quite a bit of cutting and trimming to the body cladding, as well as notch and bend some of the pinch welds.. It was not hard to do, but it will need to be done. If you do not have the body cladding it will be a little easier to make them fit, but I also found the cladding hides a lot of the cutting and banging I had to do.. I f you are patient and take your time you can trim it and make it look really nice. Just go slow and remove a little at a time so you dont remove more than neccessary..
1999 Astro 4WD
NP231c Transfer Case Conversion, Custom Shifter and Front Driveshaft, 31x10.5x15 BFG AllTerrain, Custom Warn Front Bumper, DHC Rockrails, Superwinch 5000lb winch, Warn Spotlights and Flood lights on Custom Mounts, Thule Roof Racks Safari Rack and Kayak Racks, Alpine Touchscreen AM/FM/XM/CD/DVD/iPod, Eclipse Amps, Focal Utopia Component Speakers, Alpine TypeR 12" Subs, and probably lots more I am forgetting.... seems to happen more and more these days...
9dawgs
Post by 9dawgs »
I have my 31s on stock wheels and a 4" OLV lift. The tire rides tall so you'll have to trim a bit. Its doable and will come out real clean looking if you are careful. There are a few write ups on this website of the process along with photos.
Jim<><
'99 Astro 4X2, (RIP) 4" Overland Lift, 31X10.50/15 BF Goodrich AT T/A KO,
Rancho RS5000 shocks, Rockford Fosgate RFX9000, Red Top Optima, K&N Filter
'98 Astro 4X2 (SOLD)
LaGrasta
Has thanked: 2 times
Post by LaGrasta »
Even with only a 2" OLV lift and 30 BFGs, I had to trim around the front wheel well quite a bit. The end result is no one can even tell I was there. It looks great and it looks stock.
My problem is I have no room on the back tires for chains, too close to the front of the wheel well. I'd love to see some pics of those ares trimmed.
1998 Astro, 246,000 miles
FireVan
Post by FireVan »
LaGrasta wrote:Even with only a 2" OLV lift and 30 BFGs, I had to trim around the front wheel well quite a bit. The end result is no one can even tell I was there. It looks great and it looks stock.
That is where the OV spring hangers can help out. They move the springs back a little to provide clearance there. You could also redrill your stock spring hangers to move the springs back and down. You will gain about .75" more room for your tires/chains and about .5" in height. You just have to drill a new hole 1" lower and centered (.75" back). You can also reverse the stock hangers but that will move you back to the point you start crowding the rear.
BTW-If you need to remove them you will have to undo the gas tank inside mounts while supporting the tank on a stand. Then remove the filler and slide the tank towards the driveshaft to have room to get those long spring hanger bolts out. You may also have to undo some exhaust hangers and push the muffler towards the driveshaft.
89 2WD, Gry/Slv, booster shocks & 235s, (sold)
92 AWD, Blu/Slv, +5, 31, 15x8 (The original lifted van)
93 2WD, Cargo, +5, 30, 15x7, G80 (sold)
94 AWD, Smurf Blu, +5/6, 235, Bumpers, Skid (sold)
96 AWD, Blu/Slv, +2, 235, (sold)
96 2WD, Wht/Blk, +8, 245, 16x7, G80, (4sale $2750)
98 AWD, Red/Blk, +6/7, 31, 15x8, G80, (Custom Bumper - Soon)
LaGrasta
Post by LaGrasta »
Firevan, how does this mod affect the shocks, brake lines, etc?
FireVan
Post by FireVan »
LaGrasta wrote:Firevan, how does this mod affect the shocks, brake lines, etc?
Not at all. Such a mild relocation that it isn't even noticed. Rear axle is only .75" back with either the redrilling method or the OV HiPo hangers. It is only .5" lower with the redrill and up to an inch or so with the OV ones. Remember that lowering only one end of the spring will only raise the vehicle by half the amout you move it. Thats why the hole redrilled 1" lower only gains you .5" and why 4" longer shackles only lift it 2".
FireVan
Post by FireVan »
cd0156 wrote:Image
I have BFG A/T KO 31/10.5/15 tires on mine with a 4" Overland lift... neccessary..
I like the look of that front bumper. What model was that you used and what changes did you need to make to it? I am planning on building one but if i could find a ready made one that works that would save me some time. Thanks.
scarecrow
Post by scarecrow »
FireVan wrote:
cd0156 wrote:Image
go here...
viewtopic.php?f=7&t=4025
LaGrasta
Post by LaGrasta »
I see, thanks. I may just give this a try sometime.
